First post, by dhruba.bandopadhyay
I need something cleared up. There's a setting in DOSBox.conf file that says:
ipx=true #enable IPX emulation over IP/UDP
Does that mean it converts the IPX packets so it works over UDP. Does that mean we can play DOSBox over the internet, since UDP is a internet related protocol?
Please sign the Blood source code release petition
Reply 3 of 6, by MiniMax
Rank Moderator
Moderator
DosBox Guide to Multiplayer Games
_________________
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
which is a bit outdated
at least when it comes to the problem mentioned with games at the bottom.
Water flows down the stream
Reply 5 of 6, by leileilol
I did a IPXNET game of ROTT with a friend before, worked
PS. I've never gotten OMF2097 or Tyrian netplay to work on actual DOS systems at all either, so those are pretty bad examples.
Reply 6 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I currently don't know any games that do not work.
1+1=10
