date command
First post, by mutato
Hi. I recently choose dosbox for emulate some old DOS applications inside Debian and Ubuntu. Instead dosemu or qemu + freeDOS dosbox have a lots features that oriented my decision.
Now, I have two problems.
1) Access to parallel port, but I'm work around.
2) Standard DOS date command.
How can I implement date command into dosbox?
Openclose.it - Free Software Rules
http://www.openclose.it
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
A date command? Either put a DATE.COM program somewhere in a mounted drive, or implement DATE as a built-in command by changing the DOSBox source code.
_________________
