D-Fend Reloaded (DOSBox frontend)
Reply 1581 of 2253, by hakanates
Hi Alexander, this is Turkish language file for DFR 1.2
new strings fixed, you can use it.
have a good time
    Turkish_1.2.zip
    35.94 KiB
    385 downloads
    tr 1.2
Reply 1582 of 2253, by Alexander
Hi hakanates,
thank you very much, I have just added your updated language file.
By now only few language file updates are still missing. I will wait for them about a week and then release 1.2.
Reply 1584 of 2253, by sst
Hi, ...
@Alexander
@Alexander
If i understand your last post, some translation(s) not updated block the release ?
No bug to report.
Reply 1586 of 2253, by Alexander
Hi everybody,
I have changed the Syndicate auto setup template and also fixed 3 GUI bugs related to user-defined emulators and ... finally released D-Fend Reloaded 1.2. Have fun!
Reply 1587 of 2253, by Neville
I'm not sure about that new "Syndicate" template. It lists memory as 16 Mb and the game has a well known problem with that, it will crash after completing two missions in a row unless you set it to 8.
Reply 1588 of 2253, by sst
Hi, ...
I use = D-Fend Reloaded, "v1.2", Portable structure.
@Alexander
Do you have "forgotten" to add, the latest "7za.dll" x86 ( 2011-4-18 ), version, inside the final "D-Fend Reloaded v1.2" ?
Because, your "D-Fend Reloaded v1.2" Portable structure, contain the "7za.dll" x86 ( 2010-11-18 ), version.
Then, ... please add soon, the "7za.dll" x86 ( 2011-4-18 ), version.
Reply 1589 of 2253, by Sheriff Hobbes
Alexander, is it possible to remove pre-defined categories from the tree structure, like "Favorites", "Language", etc.?
Thanks,
SH
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Reply 1590 of 2253, by RoyBatty
How do I submit a profile? I made a new one for Dark Forces because the old one seemed to be for German version of the game and didn't recognize the exe crc, as well as it was setup wrong.
Reply 1591 of 2253, by T.B.
Hello Alexander,
after the new 1.2 update I'm always getting the following error message after confirming the last step while adding a new game with the wizard.
"Listenindex überschreitet das Maximum (0)"
The game will be added but I have to edit it once to see genre, developer, year, ... correctly in the list.
I'm using the portable D-Fend Reloaded mode with about 700 profiles.
Reply 1592 of 2253, by tsampikos
I can confirm the error that T.B. mentions. It happens with the latest (1.2) version of d-fend reloaded no matter if setup or update exe. I have less than 700 profiles that T.B. has. Strange bug! 😦
Reply 1594 of 2253, by lukeman3000
T.B. wrote:
Hello Alexander, […]
Hello Alexander,
I get this same error as well. And when I would try to run the game, it would tell me something like "There is currently no mounted folder that can access the specified path" or something along those lines. However, that isn't appearing anymore.
The error seems to be occurring as a result of choosing the "default user template" during the wizard process. My template default template was always working fine before the 1.2 update, and if I manually add a game (not using the wizard), the profile creator properly reflects my default template and I do not get an error.
So in summary, the error appears when:
1. I use the wizard to add a game
2. I choose "Use user-defined template/Default template"
I am running 1.2 on my windows 7, 64-bit desktop pc. Hope this helps.
Beyond that, everything seems to be working great. And I am very happy that scumm games now work! It's great. Thanks for your hard work on this project, it is much appreciated and enjoyed.
Reply 1596 of 2253, by Alexander
Good evening everybody,
@sst:
The 7za.dll from 7-zip 9.22beta seems to be buggy: When using it with the TSevenZip wrapper in D-Fend Reloaded I get strange error messages. So I will stay at 9.20 and wait for the next 7-zip version.
@Sheriff Hobbes:
No, they are always available in the filter tree.
@RoyBatty:
Just mail it to me.
@T.B., tsampikos and lukeman3000:
This bug is due to the new multiple internet addresses per profile feature. As you have already found out, it only appears when choosing the default template in the new game wizard.
I have also fixed a wrong language string in the games popup menu and will try to release a first service release of 1.2 next week.
Reply 1597 of 2253, by tsampikos
I have searched a little bit around to see if there are any DOSBox frontends comparable to D-Fend Reloaded. Well, there ae not any! That's why it is important to support the work that Alexander does.
I have switched back to the 1.1 version and I will wait for the sevice 1.2 release next week.
Reply 1598 of 2253, by sst
Hi, ...
@Alexander
I have found a name change bug, inside the screenshot section.
It's when i move the D-Fend Reloaded window, when displaying a game profile, that have 3 or more screenshot.
To reproduce that bug =
Use the windowed option
After display a game profile, that have 3 or more screenshot(s)
After move D-Fend Reloaded window "left to right" and "right to left".
After when you move D-Fend Reloaded window, you will see that the screenshot name(s) and number(s) for a profile change.
I can made a small screenshotvideo, that display that name change bug.
Reply 1599 of 2253, by Sheriff Hobbes
@Sheriff Hobbes:
Then I make this an official feature request. I'm a tidiness fanatic and I don't want to have filters listed that I never use! 😀
-engagement ring
-wedding ring
-suffering
H. L. Mencken
