First post, by marooned_on_mars
I don`t know why this occurs with DosBox, it did not happen so often before but now it is going on every time I start DosBox, and before this happened mostly in windowed mode, now it happens even in the full-screen one! If I want to get rod of it I have to switch between the modes, and it`s quite annoying as some games are quite "sensitive" and they receive the "enter" command before DosBox switches the mode. I have DosBox 0.72 on Windows XP Sp3, it never happened in Ubuntu. I`ve seen this occur into another application that uses DirectX through SDL. Is there any solution to my problem?
Reply 1 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
check which programs run in the background. especially if they have a trayicon (those can change the palette suddenly and then dosbox is messed up) Notorious ones are dvd playback monitor programs.
Water flows down the stream
Reply 2 of 9, by marooned_on_mars
Tested with no icons in the taskbar (other than the volume control one) still the green screen appears, and I don`t think that can be the cause, maybe a hardware and software fail? Or maybe the SDL library is smashed? Or DirectX is the problem? (tho I tried with multiple versions of it). I only know that the DosBox version that had the old logo did not have those problems.
Reply 5 of 9, by DosFreak
Upgrade video drivers
Verify that nothing in your startup is interfering (Use Autoruns from Microsoft)
Download gulikoza's build of DOSBox and try Direct3D.
Make your games work offline
Reply 6 of 9, by marooned_on_mars
I have all the drivers updated (well, not really for my video card, but I cannot upgrade, as the support in the newest drivers for my card is quite deplorable).
I cannot use a custom build unfortunately, because I use D-Fend Reloaded, not that I don`t know how to fiddle with DosBox`s settings, it is because I like to start my games at one click. If this problem was only for one game I would say yes, but this is different. Thank-you for your suggestion tho., I might try it one day, the build looks promising, and has Munt in it too 😁
What do you mean by "M$ Autorun"?
Reply 7 of 9, by DosFreak
marooned_on_mars wrote:
What do you mean by "MS Autorun"?
http://technet.microsoft.com/en-us/sysinterna … s/bb963902.aspx
You could try the sdl.dll from an older version of DOSBox.
Reply 8 of 9, by Miki Maus
With DosBox 0.72 on Windows XP SP3 I had best results with output=ddraw regarding speed and picture quality. I always found overlay glitchy and opengl somewhat slow with some games.
Reply 9 of 9, by marooned_on_mars
DosFreak wrote:
Ah, I see. I prefer to use M$Config, without the need to download other programs.
Wouldn`t this make my current DosBox more incompatible, or decrease it`s speed?
Strangely I used to recall the direct draw render as slow. Now I`ve tested with some "heavy" games and it seems that it is about as fast as overlay is.
If it is less buggy I`m willing to switch to it 😀 . Thank-you for the suggestion.
