Pentium emulation?
First post, by Wulf
I'm trying to install & run Psygnosis 'Destruction Derby 2' on my Windows 7 x64 machine. It won't run in Windows, it's incompatible with 64 bit processing, but there's a DOS version on the CD. However, this isn't a game-specific question...
When I try and run the DOS installer through DOSbox, it tells me
"This game requires a minimum of a Intel Pentium processor -
Your system only contains a Intel 80486 processor"
Now, since I have an AMD processor, I figure it's DOSbox telling the program what CPU I have - is there a way to tell it I have a Pentium?
Reply 2 of 3, by DosFreak
You could try the "pentium_slow" cputype in DOSBox.conf and see if that works. If not then hopefully it's something as simple as a CPUID check that could be implemented.
As for the Windows ver of DD2 I've tested it using on a 7 64bit host with Vmware Workstation 6 and Windows 2000 as a guest OS and it works fine.
Make your games work offline
