First post, by dbandy
Hi,
I've used 0.73 with COM1 mapped to serial1 as directserial. As I understood serial1 is the DOS COM port COM1 and so on.
This is currently working. But no other COM port can be used i.e.
serial2 with COM1 or COM2
or serial1 with other than COM1
So I tried 0.74. In 0.74 there is NO COM port working.
I'm using Windows XP and com0com for virtual nullmodem. Other applications have no Problems with com0com. I'm using it extensively.
Does anyone have a suggestion?
Thx
Andy
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
did you modify the configfile of dosbox in order to enable them
com ports work fine. Lots of people use them
Water flows down the stream
Reply 2 of 7, by dbandy
Yes. Like:
serial1=directserial realport:COM2
serial2=disabled
or
serial1=directserial realport:COM1
serial2=directserial realport:COM6
The only configuration working in 0.73 is:
In 0.74 this doen't work too.
Reply 6 of 7, by dbandy
DOSBox version 0.73
Copyright 2002-2009 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file test.conf
MIDI:Opened device:none
Serial1: Opening COM1
Serial2: Opening COM6
DOS keyboard layout loaded with main language code GR for layout gr
Reply 7 of 7, by dbandy
Sorry. It's always good to talk to somebody. Now I've found the problem.
It's the god damn windows.
When you have a look at my start batch there's a %1.
So I drop a folder on the start script and DOSBox will mount this at C.
But windows changes the current working dir to elsewhere and the special test.conf is not found and the default from my user dir is used. There serial1 is mapped to COM1 and the other are disabled. Hmph.
Now without the option -noconsole I can see wich conf is used and how the COM ports are mapped.
Sorry, Sorry, Sorry.
