I guess I didn't really describe the problem properly.
When I start the game with the correct CPU cycles, it runs extremely fast. It's a time based game, measuring your accomplishments in days and weeks and I can literally do nothing while I watch 50 weeks pass by in two seconds. Normally, the game takes its time to count down with whatever method it uses to count time but, this game runs fast. So fast, in fact, that when I try to do anything, I can't because a message will pop up telling something is happening.
I tried lowering the CPU cycles to 50 but all that does it make the graphics draw slowly and make it impossible to drive the little car. The controls are almost non-responsive. Time still passes extremely fast considering the CPU cycles are slowed down.
If I run this game in Windows Compatibilty mode, it runs the time correctly however, messages and events briefly flash on the screen making it impossible to tell what just happened. I can drive the little car find but if I go to the office in the game and try to pull up some information, it flashes on the screen so fast that I have to access my unconcious mind to use it.
Thanks for the non-elitist response.
