Game running way to fast
First post, by heavy
I've been trying to run a game recently but DOSBox seems to run the game exceedinly fast. The title screen flashes by and any important messages in the game flash by as well. I'm playing Snooper Troops available at http://www.bhlegend.com/php/show.php3?game=723.
I have an Athlon XP 2600+, GeForce4 and all the bells and whistles.
Thanks
Reply 1 of 9, by Snover
Ooh! OOOH! I HAVE AN IDEA!!
READ THE README!
*whack*
Yes, it’s my fault.
Reply 2 of 9, by heavy
Well thanks for the sarcasm, you elitist jerk. How about some helpful info? I read everything in the readme and nothing worked.
Reply 3 of 9, by Freddo
Lower the CPU cycles to 30 or something.
Reply 4 of 9, by heavy
I guess I didn't really describe the problem properly.
When I start the game with the correct CPU cycles, it runs extremely fast. It's a time based game, measuring your accomplishments in days and weeks and I can literally do nothing while I watch 50 weeks pass by in two seconds. Normally, the game takes its time to count down with whatever method it uses to count time but, this game runs fast. So fast, in fact, that when I try to do anything, I can't because a message will pop up telling something is happening.
I tried lowering the CPU cycles to 50 but all that does it make the graphics draw slowly and make it impossible to drive the little car. The controls are almost non-responsive. Time still passes extremely fast considering the CPU cycles are slowed down.
If I run this game in Windows Compatibilty mode, it runs the time correctly however, messages and events briefly flash on the screen making it impossible to tell what just happened. I can drive the little car find but if I go to the office in the game and try to pull up some information, it flashes on the screen so fast that I have to access my unconcious mind to use it.
Thanks for the non-elitist response.
Reply 5 of 9, by Snover
I can't be any other way when 90% of people don't read the README and the 10% that do don't follow the posting guidelines which state to say if you've read it.
Yes, it’s my fault.
Reply 6 of 9, by cometzero
I'm having exactly the same problem and I ***HAVE*** in fact read the readme. Does anyone have any suggestions?
Reply 8 of 9, by cometzero
Simply lowering the cycles doesn't help. As mentioned earlier in this thread:
"When I start the game with the correct CPU cycles, it runs extremely fast. It's a time based game, measuring your accomplishments in days and weeks and I can literally do nothing while I watch 50 weeks pass by in two seconds. Normally, the game takes its time to count down with whatever method it uses to count time but, this game runs fast. So fast, in fact, that when I try to do anything, I can't because a message will pop up telling something is happening.
I tried lowering the CPU cycles to 50 but all that does it make the graphics draw slowly and make it impossible to drive the little car. The controls are almost non-responsive. Time still passes extremely fast considering the CPU cycles are slowed down."
Reply 9 of 9, by wd
Rank DOSBox Author
DOSBox Author
They are trying to change the system time. As dosbox uses the
host-OS time, this is disallowed, resulting in odd timing of
the game.
