First post, by mperelman
When I am changing an existing file, and put the old file on my C drive. My computer was just replaced and DOSBOX does not recognize the C Dr. except right after I mount the drive. When using my outliner, Maxthink, the program does not recognize the C Dr.
I can close the program, which leaves me with the command prompt, which does recognize the C drive.
I have not had a problem like this in my older backup computers.
Thank you
Michael
Michael Perelman
Economics Department
California State University
Chico, CA
95929
530 898 5321
fax 530 898 5901
http://michaelperelman.wordpress.com
Reply 2 of 7, by mperelman
The conclusion is pretty simple. The program normally has the capacity to show the contents of different directories.
Maxthink is a DOS program and the command to show a directory is DOS command. If I shut down the program, I can use the D)S dir command, but I cannot save a file to D:\
Michael Perelman
Chico, CA
95929
530 898 5321
fax 530 898 5901
Reply 3 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It depends on your mount command AND on your host OS -> maybe the folder you mounted as C (or D?) does not have the correct rights to save to.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 7, by collector
Probably a permissions issue. Try mounting a non-system as your emulated "C:" instead of the root of your system drive.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 5 of 7, by mperelman
I tried to give the C drive all permissions. I am running window 7
Michael Perelman
Chico, CA
95929
530 898 5321
fax 530 898 5901
Reply 7 of 7, by Dominus
DOSBox Moderator
Yes, it's an important security measure of Newer Windows than XP to make the root of C read only. And an important security measure of Dosbox not to mount the root of C.
