First post, by bonzille
I have been learning how to use DosBox over the last couple of weeks and most things I have found to be way easier than I thought they would be. I am having some issues with pkunzip it works well but how do you tell it to unzip to a ceratin folder as I would like to keep all my games in seperate folders.
I have installed pkunzip to c:\oldgames and any game in the folder I can unzip but I can't seem to unzip any archive that isn't in the same folder as Pkunzip is there any way to tell pkunzip the path to the folder that the zip archive is in.
Thank you
Reply 1 of 7, by Gmlb256
Hello.
To be able to use PKUNZIP outside of C:\OLDGAMES you should add that directory into to the PATH environment variable. In this case it should be the following:
SET PATH=C:\OLDGAMES;%PATH%
%PATH% is to keep the original PATH environment variable intact while adding the new directory and I recommend adding this line in DOSBox configuration file on the [autoexec] section so you don't have to type this each time when starting DOSBox.
Reply 2 of 7, by konc
Adding pkunzip to the path is of course the way to go with such a utility that you use often.
Generally speaking, you can also specify the full location of a program to run it from a different location, for example
C:\DOOM> C:\OLDGAMES\PKUNZIP.EXE ...
Reply 3 of 7, by Peter Swinkels
Why not just use Winzip or a similar program for Windows?
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 5 of 7, by DosFreak
There's also 7zip for DOS if you want to use something current that you'd also potentially likely use on a modern OS if/when you didn't want to use a GUI
7-Zip Benchmark, DOS Edition
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 7 of 7, by bonzille
konc wrote on 2021-10-30, 08:01:
Thank you finally got the hang of it not that I think I will use it that much as I find it way easier to use 7 zipper and extract the files straight to the folder but it is nice to know how to do these things as my first PC was a Windows 98 PC so I never got to use Dos .
