First post, by Joey3155
Motherboard: Intel Schroeder Town G33 Motherboard (OEM version of Intel DG33SXG2 motherboard)
Processor type and speed: Intel Core 2 Quad Q6600 Kentfield @ 2.4 GHz per processor
Amount and type of RAM: 2 GB DDR 2 RAM @ 800 MHz (I think though the amount is certain)
Video board w/ RAM amount and type: NVIDIA GeForce 9600 GT with 1 GB VRAM
Sound board: Creative SoundBlaster X-Fi Fatality
Operating system: Microsoft Windows Vista Home Premium 32 bit version pre SP 1
Game name: Any game I try to run though the most recent example is Rise of the Triad v1.2
Description of problem: When I go to run a profile in D-Fends DOSBOX will start to load the file I might even be able to see the new screen for half a second or a full second. But afterwards it crashes back to desktop with a "DOSBOX DOS Emulator has stopped working" message with the following problem signature. I'm going to assume that it will be interesting to note that I was using D-Fends and DOSBOX several months ago with no problems I stopped using the two because my attention was drawn elsewhere and I came back to using them today to try some more DOS games and this is the problem I experienced.
Problem signature:
Problem Event Name: APPCRASH
Application Name: DOSBOX.EXE
Application Version: 0.73.0.0
Application Timestamp: 4a1d0c79
Fault Module Name: SDL.dll
Fault Module Version: 1.2.13.0
Fault Module Timestamp: 49f5c79b
Exception Code: c0000005
Exception Offset: 0003f3e3
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional Information 1: 8d13
Additional Information 2: cdca9b1d21d12b77d84f02df48e34311
Additional Information 3: 8d13
Additional Information 4: cdca9b1d21d12b77d84f02df48e34311
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Reproducibility of problem: Always, Guaranteed.
Sound mode used: Whatever is the D-Fend/DOSBOX default
Video mode: Whatever is the D-Fend/DOSBOX default
Version of emulator: DOSBOX 0.73, D-Fend Reloaded 0.9.1
Steps already attempted to solve the problem: Reinstalled using newest version of D-Fends Reloaded which includes DOSBOX 0.73. Thinking of restarting PC hoping it'll help. Can't think of anything else that might help.
Reply 1 of 5, by DosFreak
Try different output= in DOSBox.conf. It's possible a video driver update is causing this.
Make your games work offline
Reply 2 of 5, by Joey3155
Thank the moons, I feel so stupid. I made the stupidest mistake possible!
You were right it was a problem with the video output mode but I forgot also to set it to VGA. DOSBOX had defaulted to SVGA 3. ARGGH! I could kick myself...
Reply 3 of 5, by Joey3155
Now I have another problem. The install program loads up fine and actually does not crash. I can select the drive, the program path to install to, I'm using the default of C:\ROTT, however when I hit enter to actually start copying the files over I get a garbled black screen which is actually the DOS black screen and I have to type "exit" in order to escape. It's as if the emulation quitted the install and I don't know why.
Reply 5 of 5, by Joey3155
I fixed it. I help to download the Windows version of Rise of the Triad but the DOS executable works fine in this copy of it. So DOSBOX is working again and now whenever I want a new experience I can also play ROTT for Windows. 😀
