First post, by ariqu
- Newbie
I've read the other threads about how Mechwarrior stopped working sometime after .62 and about the 'intelligent=false' for the config file, but I've also seen mentioned that the intelligent variable is no longer read.
I've poked and prodded at it with and without memory management, low cpu cycles on all 3 of the cores, but I can't get this thing to come back from a mission. Dynamic core setting crashes DOSBox completely after a mission, the other 2 cores simply show that the running program has switched back to MW_MAIN from BTECH(the '3d' portion), but sits a blinking cursor.
So, is Mechwarrior still broken?
