First post, by research_tech
I am trying to get an old scientific/research program called ASYST by Software Technologies, INC. (Macmillan Software Company) to function in a new windows 7 computer for a research technician. I used DOSBox and the program seems to run, but is having an issue with one of its commands. It uses a DIR command similar to DOS itself, but when using this command within the ASYST program it displays "0 File(s), 0 bytes used" when it should show the files in the directory. I am able to see the files in a regular DOS window using the DOS DIR command, and I am also able to see the files doing a DIR command from within DOSBox after mounting the drive (but prior to launching the ASYST program).
I have a suspicion that the ASYST program is having trouble seeing files on a mounted drive. Is there some configuration I am missing? I looked through the help files, and FAQ's but I have not found information to help in the matter. Any ideas?
Reply 2 of 5, by Matth79
DOSBox targets only the functionality required for games, pure luck if other things work.
You could try installing FreeDOS in a Virtualbox session, but Virtualbox is also not guaranteed to support a DOS environment - or if it can't get along with virtualization at all, then maybe dual booting with FreeDOS - tricky but possible - http://thebug.nerdtroop.com/TheBug/Computer_S … _dual_boot.html
Reply 3 of 5, by Jorpho
When it comes to file system problems, sometimes using a hard drive image rather than mounting a directory is a workaround.
Also, try looking at vDOS.
Reply 4 of 5, by croc
research_tech wrote on 2014-10-29, 21:32:
I was wondering you still have the software? because I was also searching for this old software. The company doesn't exist anymore. Hope to hear a response after so long time ago you posted the message here.
Or does someone else still has this program?
