DosBox and OpenSSL
First post, by PauloBrito
Thanks to DosBox I can now run an MS-DOS program in win64.
It even can call any windows printer, including pdf virtual ones.
My problem is, I need to call OpenSSL to generate an encrypted key. I get the message that openssl.exe is a windows program and doesn't work.
In win32, the program runs normally, and I call OpenSSL without a problem, but these days all new PC's come with the win64, so I have a problem.
Exist any way to make OpenSSL works / be called from a program running inside DOSBox?
Reply 1 of 5, by jmarsh
DOSBox is for DOS programs only.
64-bit versions of windows can still run win32 programs.
Reply 2 of 5, by PauloBrito
Yes, I know. My program is an ms-dos program. Run in win32 cmd. but not in win64 cmd - because uses a dos-extender. Problem his - need to call OpenSSL. In win32 no problem, in win64 inside DOSBox - no luck.
Exist any alternative to OpenSSL that works inside DOSBox?
Reply 3 of 5, by jmarsh
It's not a DOS program, it's a windows console based program. There is a difference.
The OpenSSL.exe itself is telling you that it's a windows program when you try to run it under DOSBox. Just run it directly from windows CMD instead.
Reply 4 of 5, by zyga64
Maybe this is something for you ? http://www.columbia.edu/~em36/ntvdmx64.html
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 5 of 5, by mr.cat
Your best bet is to use the win64 native version, if possible.
But if you insist on using dosbox to launch win32 program, you can try HX. It can launch *some* win32 console apps (and even some GUI apps):
https://github.com/Baron-von-Riedesel/HX
There are some small test programs included, best to check with them first.
OpenSSL is open source but distributed without binaries. But there could also be a DJGPP port out there, somewhere...
