First post, by PauloBrito
Thanks to DosBox I can now run an MS-DOS program in win64.
It even can call any windows printer, including pdf virtual ones.
My problem is, I need to call OpenSSL to generate an encrypted key. I get the message that openssl.exe is a windows program and doesn't work.
In win32, the program runs normally, and I call OpenSSL without a problem, but these days all new PC's come with the win64, so I have a problem.
Exist any way to make OpenSSL works / be called from a program running inside DOSBox?
