Reply 20 of 27, by remowilliams
If it's of any use, here's my .conf
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
language=
machine=vga
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
#scaler=2xsai
[cpu]
core=dynamic
#core=normal
cycles=auto
#cycles=3000
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=intelligent
device=default
config=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
Show last 65 lines
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
### regular Dosbox boot config ###
mount c c:\games\dosboxhd
c:
mount d: g:\ -t cdrom
### config to install floppy images to hard drive file ###
#mount d c:\games\dosboxhd
#imgmount c d:\c.img -size 512,63,16,60 -t hdd -fs fat
### config to copy installed HD file games to dosbox HD ###
#mount c c:\games\dosboxhd
#imgmount d c:\c.img -size 512,63,16,60 -t hdd -fs fat
Reply 21 of 27, by jamon51
I too love to play Gunship 2000 and have run into this bug. It is a little annoying in that I usually like to review the briefing so I can know what to expect and load out my choppers accordingly. As it is, I have to load them out with a standard vanilla mix of weapons--not a huge deal, but would be nice. Also would be nice to know how far it is to the objective before loading out.
I have Dosbox 0.70 with a standard config file.
Thank you,
Jamon
Reply 24 of 27, by Maverick1st
I know this is almost thread necromancy, but it seems to me, i found a solution for the "scrolling briefing" bug.
I simply changed the sound to ATI FX.
This works fine with me using D-Fend 0.50 and the DosBox-Version shipped with it (0.72). Only thing that does not work is the digitalized speech, but I think this is better than no Sound or PC Speaker
But i have an other problem.
I got the Bestseller Games CD with GS2000 and I&I Addon. But there was only the I&I Manual on it.
The last time i played Gs2000 was about 12 Years ago I think, so I don't remember all Keyboard commands to fly the gunships.
Does anyone of you happen to have the manual for original game?
Alas, the link at HotU is broken and i couldn't find it somewhere else in the net, exept for this amiga conversion of the manual. amiga Manual GS2000
But the Author says he changed some of keys for the didn't work correctly for the Amiga conversion, so if anyone of you can send me the Manual for the PC-Version please write me a PM.
Greetz
Maverick
Reply 25 of 27, by jamon51
🤣 this was an old thread...but it dutifully notified me that you had replied. I haven't played GS2000 in a while but I might at that. Still haven't found a chopper game worthy to be its successor.
I didn't know about D-Fend Reloaded...downloading it now.
I have my original GS2000 manual from when my dad bought it in the early 90s but no way I'm parting with it. I'll attach what I have here. Let me know if you still need help.
    GS2KHINT.TXT
    22.25 KiB
    377 downloads
    Gunship 2000 Hint File
    g2000keys.txt
    3.97 KiB
    359 downloads
    Gunship 2000 Keyboard Commands List
Reply 26 of 27, by Maverick1st
Thats exactly what i needed. Many Thanks. I attached the GS2000.conf.txt which my D-Fend created. Only thing you have to change should be the path to your files since i didn't work with relative paths there.
Hope this works for you.
And many thanks again for the fast help.
*Edit*
I don't understand this. yesterday evening i tried around 20 times with ATI FX and everytime it worked. Today i get the same bug again.
So it seens this wasn't the solution for the problem. Sorry.
*another Edit*
Ok, I tried setting the core emulation to to dynamic and cycles to 6000. Now it not only runs much smoother, but also the bug is gone. At least it was the 10 times i tried. I also set back the Sound to Soundblaster and it also worked with this. I attached the changed conf file.
    GS2000.conf.txt
    1.59 KiB
    324 downloads
    GS2000 D-Fend Reloaded conf
Reply 27 of 27, by MiniMax
Rank Moderator
Moderator
Pilots, please continue your chatter here:
Gunship 2000 chatter
_________________
