First post, by whitesmith
When I attempt to run Norton Ghost 2002 I get a processor exception error (see attached file) and Dosbox immediately shuts down.
I'm running Windows XP with SP2 and all current patches on a PC with an ASRock mobo (P4 3 GHz processor), 1.5 GB RAM, and NVIDIA GeForce4 MX 4000 graphics.
Thanks -- any help/suggestions would be welcome. I know there are newer and better ways of backing up, but my company insists on using Ghost from within Windows.
    GHOSTERR.TXT
    1.88 KiB
    380 downloads
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Ghost inside DOSBox 😳 Are you sure you are running DOSBox? If so, which version?
_________________
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
Well you also indicated that Ghost dies IN dosbox, which doesn't make
too much sense. Guess you mean that Ghost dies during the backup process
when dosbox is active, right?
What about 0.70? Does it work there?
Reply 4 of 8, by DosFreak
Just create the Ghost boot disk and boot it on the PC you want to image.
As for your company insisting on using Ghost. Do a comparison between Acronis/Ghost, pricepoint features. Run some actual tests etc, etc. After your done you'll be able to by Acronis and be happy.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 5 of 8, by whitesmith
To be precise, Ghost dies in DOSBox before it even displays a screen. The old version of Ghost we own (2002 with a boot disk) is intended to run in real mode, yet my all-knowing boss insists that it can be made to run in Windows. If it can't, the fault is obviously mine, which means my job is toast. I'm sure Acronis is the better choice, but it just isn't an option where I work.
Reply 6 of 8, by MiniMax
Rank Moderator
Moderator
Poor you. Better dust of that CV/Summary and find a new job.
_________________
Reply 7 of 8, by wd
Rank DOSBox Author
DOSBox Author
Ok but dosbox is DEFINITELY not the thing to use for such stuff,
its aim are games, not fail-safeness and usability for backup systems.
Reply 8 of 8, by red_avatar
I'd say, stay off any Norton virusses - sorry, software. Except their software acts like a virus, slowing down your system, installing crap left and right, replacing Windows items with Norton variants, and in the end causing games and programs to crash, etc.
