First post, by Bartosz
That's right, I've try load A4 Networks (it's four part of a-train game) in Dosbox and I got that message MEMORY 01 - NOT ENOUGH EMS MEMORY
Can somebody help me with this problem ?
Reply 1 of 41, by Qbix
Rank DOSBox Author
DOSBox Author
I take it that you tried to increase the amount of memory by editing the configuration file of dosbox ?
Water flows down the stream
Reply 2 of 41, by MiniMax
Rank Moderator
Moderator
Bartosz - please execute the following commands in DOSBox, and report the results here.
Z:\>ver
Z:\>memsize
Z:\>ems
Z:\>xms
Z:\>mem
_________________
Reply 3 of 41, by Bartosz
No, I do nothing with incease of memory.
Ok, so:
ver:
DosBox version 0.72. Reported DOS version 5.0.
memsize:
16
ems:
true
xms:
true
mem:
634 kb free conventional memory
63 kb uper memory in 1 blocks (largest UMB 63 kb)
15280 kb free extended memory
15280 kb free expanded memory
Reply 4 of 41, by MiniMax
Rank Moderator
Moderator
Okay - now try to do as Qbix suggested. Edit the file dosbox.conf and change memsize=16 to memsize=64.
Start DOSBox and verify (with the memsize and mem commands) that your changes are active. Then start your program.
_________________
Reply 7 of 41, by MiniMax
Rank Moderator
Moderator
Try the command 'loadfix' before you run the program.
If that doesn't help, try the command 'ems false' before you run the program.
_________________
Reply 10 of 41, by Bartosz
Winsows XP SP2
AMD Athlon XP 2600+
1.91Ghz, 768 MB Ram
GForce 5200 FX 64 MB
Can I ask you something? Here are the site I've dosnloaded A4 Can you download and check this game on yours computers please? 😉 It's only 4MB.
Cheers
/EDT Link removed. Abandonware is wrong!
Reply 16 of 41, by MiniMax
Rank Moderator
Moderator
Bartosz - uninstall DOSBox, reboot, install DOSBox, try again.
_________________
Reply 18 of 41, by MiniMax
Rank Moderator
Moderator
Is this the first and only program you have tried with DOSBox?
_________________
Reply 19 of 41, by Bartosz
No, earlier I played A-train and Simcity with it and there wasn't any problems. But I see thay A4 can be loaded without Dosbox because the same problem is when I start it normally in Windows
