First post, by Bartosz
That's right, I've try load A4 Networks (it's four part of a-train game) in Dosbox and I got that message MEMORY 01 - NOT ENOUGH EMS MEMORY
Can somebody help me with this problem ?
I take it that you tried to increase the amount of memory by editing the configuration file of dosbox ?
Water flows down the stream
Bartosz - please execute the following commands in DOSBox, and report the results here.
Z:\>ver
Z:\>memsize
Z:\>ems
Z:\>xms
Z:\>mem
_________________
No, I do nothing with incease of memory.
Ok, so:
ver:
DosBox version 0.72. Reported DOS version 5.0.
memsize:
16
ems:
true
xms:
true
mem:
634 kb free conventional memory
63 kb uper memory in 1 blocks (largest UMB 63 kb)
15280 kb free extended memory
15280 kb free expanded memory
Okay - now try to do as Qbix suggested. Edit the file dosbox.conf and change memsize=16 to memsize=64.
Start DOSBox and verify (with the memsize and mem commands) that your changes are active. Then start your program.
_________________
I would try memsize=32 first.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
I've changed to 64, thetn to 32 and there is still the same problem witm ems memory 🙁
Any other ideas?
Try the command 'loadfix' before you run the program.
If that doesn't help, try the command 'ems false' before you run the program.
_________________
Still the same problem 🙁
Post your system specs, dosbox version etc.
Winsows XP SP2
AMD Athlon XP 2600+
1.91Ghz, 768 MB Ram
GForce 5200 FX 64 MB
Can I ask you something? Here are the site I've dosnloaded A4 Can you download and check this game on yours computers please? 😉 It's only 4MB.
Cheers
/EDT Link removed. Abandonware is wrong!
Works just fine.
Don't you know how can I increase EMS memory on my computer?
Maybe buy an ems expansion card.
No, I won't do that. Waste of money 😉
Probably I'll gave up. I love this and I would like to play it a lot but this problem hasn't got a solution 🙁
It has a solution, that is dosbox. Dunno what's messed up on your installation,
works out of the box.
Bartosz - uninstall DOSBox, reboot, install DOSBox, try again.
_________________
I'm out of my mind - still the same problem even when I'm trying open A4 without Dosbox. I was trying open A4 in my dad's comp but there is still the same problem with EMS.
Is this the first and only program you have tried with DOSBox?
_________________
No, earlier I played A-train and Simcity with it and there wasn't any problems. But I see thay A4 can be loaded without Dosbox because the same problem is when I start it normally in Windows
