First post, by Piesou
Symphony is my only Dos program.
Before discovering DosBox, I needed a stand alone computer to run Sym2 under XP. With DosBox, I can run simultaneously XP programs in their windows and Sym2 in its own window... and discard the 2nd computer.
Thank you to DosBox for this good step. But now I have a few questions.
The major one : When I start Sym2 under DosBox, CPU usage stays under 5% for around 10 minutes, then it shoots up to between 60 and 90, slowing down every running program.
Note : Unneeding sound or else, I already discarded, in Dosbox.conf, all unneeded functions. The problem stays even after I reduced DosBox priority to normal, should I go below that ?
Suggestions would be apreciated. Thanks
