First post, by Piesou
Symphony is my only Dos program.
Before discovering DosBox, I needed a stand alone computer to run Sym2 under XP. With DosBox, I can run simultaneously XP programs in their windows and Sym2 in its own window... and discard the 2nd computer.
Thank you to DosBox for this good step. But now I have a few questions.
The major one : When I start Sym2 under DosBox, CPU usage stays under 5% for around 10 minutes, then it shoots up to between 60 and 90, slowing down every running program.
Note : Unneeding sound or else, I already discarded, in Dosbox.conf, all unneeded functions. The problem stays even after I reduced DosBox priority to normal, should I go below that ?
Suggestions would be apreciated. Thanks
Reply 2 of 5, by Piesou
Thanks but no change.
Even tried 25% and lowest priority and not working with Sym2. No good. And it seems the lower the cycles %, the quicker CPU usage reaches the 60-90 band...
Help ! I waited too long to find DosBox.
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
try a fixed amount of cycles
cycles=5000
and maybe
core=normal
as well
Water flows down the stream
Reply 4 of 5, by wd
Rank DOSBox Author
DOSBox Author
Might be unrelated to dosbox actually, sounds like some virus/other
background app takes action after a while.
Reply 5 of 5, by Piesou
No, wd, I am talking about DosBox CPU usage. It looks more like something in DosBox fires up after a while...
QBix : Applied suggestions. Still no good.
Thanks, Pierre
