First post, by blade12588
i was wondering if any one could help me. im trying to install my old copy of x-com on vista using dosbox and i can get it to install but when i go to run the program it kicks back a message "SHELL: redirect output to nul"
iv read every faq on here abut runnning x-com an no one has seen to have this problem
im using dosbox 0.72
toshiba labtop model satellite a215
processor amd turion 64 x2 mobile tech tl-64 2.20 ghz
ram 3070
32 bit op sys
avi radeon graphics card
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Do you start the game with some BAT-file in DOSBox?
_________________
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you mounted the cdrom as well ?
the game should work well as I recently helped with the release of it on steam and encountered no problems
Be sure to install the game from within dosbox as well.
Water flows down the stream
