First post, by sehh
I finished EOB1, moved my characters to EOB2 and now I've also finished EOB2 and moved again my characters to EOB3.
While EOB1 and EOB2 play 100% fine under dosbox without much fiddling of the settings, EOB3 is a different story.
While it runs and plays fast enough, the audio seems messed up. Either its too demanding or incompatible with dosbox. The effects are a little "delayed" or completely miss playing.
For example, when 4 enemies hit me and I cast a fireball spell at them, I hear the enemy "hit" effect but the fireball explosion isn't heard.
Another example, is when I "hit" with 3 swords of mine, one after the other. I hear the first and second "wwoosh" sound effect but the third is either never played or delayed by a second or so.
This never happened when I was playing the game on a real machine with a real sound blaster card. So, I'm trying to figure out if the issue is that dosbox doesn't fully (or properly) emulate a sound blaster 16, or that dosbox isn't configured properly by me.
Anyone with EOB3 can please give it a try and let me know if its possible to fix the audio issues?
sehh
Reply 1 of 7, by sehh
For reference, here are my current settings (some of them that I think are relevant):
emulation core: auto
cpu type: auto
cpu cycles: max
memory: 63 MB, Use XMS, Use EMS, Use UMB
window/fullscreen resolution: original
Start in full screen mode: enabled
Use double buffering: disabled
Keep correct aspect ratio: enabled
Render: surface
Video card: vesa_nolfb
Scale: super2xsai
Activate sound: enabled
Use mixer: disabled
the rest are left at their default values.
sehh
Reply 2 of 7, by eL_PuSHeR
Rank Moderator
Moderator
I remember the sound was already crappy on a real SB16 running under real ms-dos. Besides, this game wouldn't run without EMS. It was poorly coded in comparison to Westwood masterpieces.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 7, by sehh
eL_PuSHeR, sound worked fine on my real PC, overall the game was slower on loading/starting, surely heavier on hardware but it played fine on a Pentium pc and never hard audio issues.
Qbix, when I lower the blocksize, sounds are played in half (the audio effect starts to play but its abruptly cut short).
Would it make a difference if I switched to another sound card emulation?
sehh
