First post, by gashface
I have theme hospital working with dosbox on MAC os, what I'm wondering is, is it possible to use the old level skip cheat with dosbox, and if so how should I do it?
Heres how it used to work, using terminal...
RUN..
"C:\Program Files\Bullfrog\Hospital\Hospital.exe"
now just add the -Lxx to jump to level xx:
"C:\Program Files\Bullfrog\Hospital\Hospital.exe" -L08
Can you achieve something like this on dosbox on mac osx?
Reply 3 of 8, by gashface
Hi yes, I am using a package made into a .app in there there is a dosbox launcher and wrapper and then the files for theme hospital itself. but I could easily launch the files from an external dosbox or boxer I would think?
Reply 4 of 8, by Jorpho
Then I guess you should try to do so. In the end it all comes down to typing "Hospital.exe -L08" instead of "Hospital.exe" at the appropriate spot.
However, if you have any difficulties doing so, you should probably ask the people at whatever site you downloaded this .app from.
Reply 5 of 8, by gashface
Mmm I get illegal command tried these two...
Z:\ "/Applications/hospital.app/Contents/Resources/th/HOSPITAL.EXE" -L10
Z:\ "HOSPITAL.EXE" -L10
Also tried without " and it just did nothing, any ideas?
