Can't attack running the Immortal in DosBox
First post, by polly
Hi,
I recently downloaded the Immortal (91) and tried to play it in DosBox .74 but I was not able to attack. I looked on the web and saw that the attack buttons were "A" and "B" but neither worked. I have tried almost every combination and nothing makes my character attack. I am able to dodge by holding down the enter key and hitting either the right or left arrow.
I saw under compatibility that it was tested and supported using .61 so I downloaded that but that has the same issue. Not sure what I am doing wrong. The movement is fine and everything else works great but my character keeps dying because I can't attack!!
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You need to install the full game and not a download
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 5, by VileR
polly wrote:
How can I tell it is a full version?
For one, a full version would come with a manual which tells you what the controls are. FYI, abandonware downloads aren't supported here.
also, "buttons A and B" makes me think that the instructions you found were for the NES version, but I could be wrong.
