First post, by Straker
At my local Flea market I came across a copy of X-COM: UFO DEFENSE
for $1.00 Cd only. Anyway it'[s a silver and green disc.
I downloaded the extender from the steam forums
I ran install.exe from the UFO file with DOSBOX. Yet when it asks for a install directory it keeps saying " Invalid path".
What do I do I really want to play this game and the discs in good condition.
Purple hair on the moon.
Reply 2 of 7, by Straker
Ok I got the extender from a thread on the steam forums
The install.EXE is inside the file titled UFO on the X-COM: UFO DEFENSE CD
I dragged and dropped install.exe onto the dosbox shortcut which autoruns the program.
Reply 3 of 7, by SKARDAVNELNATE
According to this UFO Extender requires Visual C++ 2008. So it won't work in DOS.
I think you mean directory.
Reply 4 of 7, by Straker
Yeah that. I forgot what it was called but yes the directory/file entitled UFO on the CD contains the INSTALL.EXE
I only found one tutorial that did not help much on the DOSBOX WIKI.
I do not know a great deal about dosbox manual stuff, I usually do the auto run thing.
Reply 5 of 7, by SKARDAVNELNATE
For getting started with DOSBox read this:
60 seconds guide to getting your game to run in DOSBox
Basically you would create a path to use as the C drive.
C:\DOS\GAMES
Then mount that and your CD drive.
MOUNT C C:\DOS\GAMES -t dir
MOUNT D D:\ -t cdrom
Then switch to the disc and install.
D:\
CD UFO
INSTALL
