First post, by Ham Fighter
I'm trying to get the old old version of Wizardry: Proving Grounds working with DOSBox 0.74 on my Mac running OS 10.7.4.
The game requires two images files, a "master" disk and a "scenario" disk. I have both of these.
After starting DOSBox, I use the following command:
boot master.img scenario.img
This boots the master disk and everything seems to run great.
My PROBLEM is that I need to be able to switch between the two disk images. Back in 1984, this would involve swapping floppy disks.
The DOSBox manual says I can switch between these disk images using CTRL-F4. But that doesn't seem to work. I hit CTRL-F4 and I'm still prompted for the scenario disk.
Is there a different key combination to switch disk images when running DOSBox on Mac OS X? Is there any way I can tell for sure which disk image is being looked at?
Thanks!
Reply 2 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
And make sure f4 is not used by some app in the os x keyboard settings
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox has a copy of lisbsdl inside on mac os X (I think). So that still uses the old code.
Water flows down the stream
Reply 7 of 8, by Dominus
DOSBox Moderator
Only svn builds are fixed. Use the one in my sig, it's a straight svn build
Reply 8 of 8, by IIGS_User
Thank you all for the informations about fullscreen.
When I write a hint about using fullscreen (my first post above),
I shouldn't forget it has been broken when Lion iOS has been introduced...
Thanks, Dominus, for uploading a fixed version! 😀
Klimawandel.
