First post, by thomy22
Hi all,
i want play a Game whit a CD-Rom. The GAme works good. But allways i start the game Dosbox say: "Sound can´t load from Cd-Rom."
Can one help me whit that problem?
Greetings
Thomy
Reply 7 of 7, by eL_PuSHeR
For instance, if the cdrom is labeled GAME01 (use vol x: command to find it, where x: is your cd drive), you should mount the cd-rom drive using the following command: mount d d:\ -t cdrom -label GAME01
Replace the D driveletter for the one you want, obviously.
