First post, by thomy22
Hi all,
i want play a Game whit a CD-Rom. The GAme works good. But allways i start the game Dosbox say: "Sound can´t load from Cd-Rom."
Can one help me whit that problem?
Greetings
Thomy
Hi all,
Greetings
Thomy
IMHO it is not DOSBOX, but the game who says it. Which game are you talking about?
Did you mount CD ROM properly (see DOSBOX README)?
Mirek
it´s MAG!
A German Game!!
but on windows XP the intro works whit sound. But on DOSBOX allways say he can´t read 🙁
No chance?
Thomy
Let's repeat, DID YOU MOUNT THE CDROM CORRECTLY?
mount d f:/ -t cdrom
is this right?
Thomy
Maybe you need to supply a label too, try adding a -label <label> statement to the cdrom mounting line.
ehm sorry? What i must type?
Thomy
For instance, if the cdrom is labeled GAME01 (use vol x: command to find it, where x: is your cd drive), you should mount the cd-rom drive using the following command: mount d d:\ -t cdrom -label GAME01
Replace the D driveletter for the one you want, obviously.
