Donald Duck's Playground CGA problem
Having problems with a specific game or application? Post your problems here!
Postby dj_anubis » 2016-9-26 @ 12:53
when i set dosbox to
machine=cga
The game loads on CGA COMPOSITE mode, does someone here knopw how to make it work on CGA RGB like in this image from MOBYGAMES?
dj_anubis
Re: Donald Duck's Playground CGA problem
Postby Scali » 2016-9-26 @ 13:36
Press 'ctrl+R' in the game to switch modes.
Scali
Postby dj_anubis » 2016-9-26 @ 14:17
I tried it but nothing happens, I set machine=cga and it start on COMPOSITE mode and then i tried to press CTRL+R on in the game but nothing happens...
dj_anubis
Postby NewRisingSun » 2016-9-28 @ 17:18
If you are using the version of the game that game designer Al Lowe has made available for free on his website, then the answer is that you cannot enable RGB mode. (The version on Al Lowe's website is the Amiga version's data files with a PC interpreter executable.)
Only the actual PC version, which is a self-booting game, supports CGA RGB mode. You can find out which version you have by pressing Alt+D. The actual PC version says "Version 1.0Q". If it instead says "Version 1.0C", you have the Amiga version with a PC interpreter executable, and if it says "Version 1.0A", you have the Atari ST version with a PC interpreter executable. (A later file-based actual PC version saying "Version 1.50" also exists, but it extremely rare, and only supports CGA RGB mode when run with the -r command line option.)
NewRisingSun
Postby dj_anubis » 2016-9-28 @ 22:48
WOW THANK YOU SO MUCH :happy:
This is amazing information, where did you learn all this info, I couldnt find it (I did look for some info before posting this post)
dj_anubis
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: No registered users and 2 guests
