The ASRock P4VM900-SATA2, VIA based PCI-e Socket 478, also own this one and is an updated version of the P4VM890 R2.0 with newer chipset
Specs:
CPU: Pentium 4, Celeron and Celeron D (Willamette, Northwood, Prescott)
FSB Speed: 400/533/800 MHz
Chipset: VIA P4M900 + VT8237S
RAM: 2 GB RAM max, DDR 266/333/400, Single channel
LAN: VIA Rhine VT6103 PHY 10/100
Audio: Realtek ALC660VD HDA
Video: Onboard VIA Chrome 9 HC (DirectX 9.0 support, SM2.0 unknown status about T&L and HW Vertex Shader, need to verify)
Slots: PCI-e x16, 3x PCI
IDE ports: 2x ATA-133 (from VT8237S)
SATA ports: 2x SATA II
OS Support: Windows 2000/XP/Vista/7 (not officially supported)
Comments:
Updated P4VM890 witth VIA P4M900 chipset, drops Windows 9x support, gets new IGP with WDDM DirectX 9 cappable GPU, but i heard is extremenly weak, even slower than the dreaded GMA 900/950, i need to futher test the board and verify the IGP features, also gets a newer southbridge with SATA II ports and replaces AC97 with HDA for the onboard audio
