So I was gonna do a whole big thing, but I've had little time, so I figured I would throw a few pics up. Tested a ton of RAM and a few HDs and CDs/DVDs.
And then there's a brace of these:
They don't power up, but I haven't had time to take them down and check. Missing a few minor bits but nothing apparently critical. One has a very small crack on the screen, so I don't know what to do about that yet.
On the other hand, this works:
AST Pentium 133 from the "funky proprietary backplane design" era, in this case apparently not to make the case smaller, but just because, hey, backplanes! CPU is good, RAM is good, replaced optical drive, was missing PSU and I have to get a switch that works properly with this case. Has built-in S3 Trio64 V+ "Turbo," Turbo apparently meaning "with less RAM" in this context. I even found out that if you go back to Hiren's boot CD version 5.0, it will boot on these 90s machines.
Seriously, this case was designed by a maniac. It's got more interdependent parts in its assembly than a Volvo. Easy 9-step processes everywhere! I'll get more detailed pics later.
I'm also glad I got a picture of this label before I found out that it's basically watercolor (or early inkjet printed on plastic film), because one swipe while cleaning wiped half of this out and it was gone.
So a reminder that just because it looks solid and it lasted 25 years doesn't mean it *is* solid. Also it was apparently never cleaned before.
Miraculously, drive rails were included, and this is my first attempt at reproducing them. I chose a 2-part design because of the shape of it, and the fact that the "arm" has to bend. I planned on using screws, and still might, but on looking at it I could probably print a pin and use it to reinforce superglue - I wasn't confident that just superglue on the flat surfaces would work that great.
I didn't get pictures yet, but I got an Athlon XP-based HP as well. Had planned to do something else today, but here I am playing with my train set.
