Reply 19900 of 30557, by Caluser2000
- l33t
aha2940 wrote on 2021-09-12, 14:50:Caluser2000 wrote on 2021-09-08, 18:41:Installing Lubuntu 10.10 on my AMDk6-2 400 rig with 256megs of ram. Why? Because I bloody well can.....😉
Just out of curiosity: what do you use an old Linux distro for? I understand using old Windows for games, but what can you run on an old Linux that you can't on a new one? honest question.
Test that old hardware is functioning correctly and it takes far less time that install Windows and a few applications. Generally I just use my hdd wih Xandos version 2 installed on it. It is great for picking up the details of hard ware systems from around 2004 back. Including nVivia video cards. Don't even need to open up the case sometimes. Just put the hdd in a usb enclosure an commect it to a usb port and set the bios to boot from that.
Also demonstrate under the hood there is not much difference between old and new Linuxs. You see *nix applications do not bloat out like MS Windows application. For evample the WindowMaker wm Is not much bigger the the version from the 2000s. And that goes for al ot of *nix applications not just Linux.
And because I can...😉
Edit:I can't remember why I had to edit this one.
