Reply 3220 of 5155, by Madao
Madao wrote on 2021-08-24, 20:18:
At saturday, i visit with friends on a scrapyard (for metal) […]
Holy shit, many old PC parts..
one xt clone with MFM full height HDD
S3 924 EISA,
INMOS Transputer Card , Hema Tek T414B
286 20Mhz motherboard with FPU
386 Motherboard with sis rabbit chipset.
ASUS Geforce 256 with huge 64MB SDRAM.
and many pearl
286-accelerator from this pile, it works.
Reply 3221 of 5155, by pan069
Madao wrote on 2021-09-01, 18:21:
What does it accelerate? The board has a 286 cpu on it? Difficult to see with the stickers. I see a socket for a 287 and an 8088? But it is an 8-bit card.
Reply 3222 of 5155, by EvieSigma
pan069 wrote on 2021-09-01, 21:07:
The CPU in the brown square socket is the 286, I presume you install the 8088 from your XT-class machine into the slot on the board so the system can boot. Some Mac accelerators were like that, requiring the CPU to be moved to the accelerator card.
Reply 3223 of 5155, by pan069
EvieSigma wrote on 2021-09-01, 21:47:
Ah, gotcha. Makes sense now. It's an accelerator for an 8088. The way I read it was that it's an accelerator for a 286 (i.e. to accelerate your 286 into something faster). 😀
Reply 3224 of 5155, by Madao
Yes, you remove 8088 from XT and install adapter with cable to 286 accelerator.
It accelerate by 286 instead 8088 since you have power it. No special software require.
And it can switch back to 8088, if compatiblity issuses is occured.
It run not stable, because i have use selfmade cable-socket adapter .
Selfmade adapter pinout is mirrored : add with pinheader and scsi cable -> correct pinout, but cable is too long.
Reply 3225 of 5155, by BitWrangler
There's a trick the iopener crowd used to unmirror a pinout with a ribbon cable, get an extra connector and crimp it alongside the first connector, tight alongside, then use the "middle" two rows to the header.
Reply 3226 of 5155, by Kahenraz
My motherboard arrived in the mail today in the retail box.
There was lots of bubble wrap on the OUTSIDE of the box. The motherboard I guess got banged around the whole way as it floated around inside.
The attachment IMG_20210902_004339_resize_47.jpg is no longer available
Reply 3227 of 5155, by mscdex
Kahenraz wrote on 2021-09-02, 06:18:
Need to protect the box so it can be used to send the motherboard back when it doesn't work. 😉
Reply 3228 of 5155, by Madao
BitWrangler wrote on 2021-09-02, 04:59:
I have use selfmade PCB with pinheader and use short IDE cable.. it translate 1:1
But i need mirrored pinout on one side. Use IDC DIL plug -> problem solved, because IDC DIP connector has mirrored pinout.
Reply 3229 of 5155, by Miphee
New management at my local waste collection place so they finally let me get some stuff. Yay!
Too bad they only do it once a year.
Reply 3230 of 5155, by Kahenraz
I bought a slot 1 CPU with an Intel branded heatsink and cooler. I wondered why the fan wasn't spinning up so I opened it up to investigate. The entire fan assembly is destroyed by corrosion.
The attachment IMG_20210902_075340_resize_81.jpg is no longer available
What's worse is that the screws that hold it to the processor housing were completely rusted and two of the four screws stripped immediately while trying to remove them.
Reply 3231 of 5155, by Caluser2000
Kahenraz wrote on 2021-09-06, 15:48:
Soak it in CRC5.56 for a day or so......
Reply 3232 of 5155, by original_meusli
Not a good sight, might be saveable though with a new fan installed and the rust removed.
Reply 3233 of 5155, by Kahenraz
The fan is very much part of the cover assembly and the heatsink is designed only to work with it.
I managed to get the heatsink off by pouring some oil around the screws and using a high quality steel torx bit that had a bit of a taper that allowed it to bite.
The next difficulty then was disassembling the processor housing as it needed a proper cleaning after having oil dripped into it. This is not an easy thing to do as the housing is pressure-fit and not designed to come apart. Later Pentium 3s are a lot better in that they are very easy to disassemble.
I did not try to reclaim the original fan shroud as I couldn't find a way to remove the fan to get at the bearing. I did keep the power cable though as those are usually missing with these second-hand Intel coolers.
Reply 3234 of 5155, by DundyTheCroc
Some goods saved from scrapping in one of our offices just came to me.
DEC tape drive model TLZ07-DA, looks like never been used.
The attachment dec_front.jpg is no longer available
The attachment dec_back.jpg is no longer available
The attachment dec_lable.jpg is no longer available
Compaq Deskpro 2000 PC, really dirty, but in working condition. 133MHZ Pentium CPU, 64MB EDO RAM, 800MB HDD, integrated Cirrus Logic CL-GD5436 with 1MB VRAM, CD drive, 3Com network card and CT2940 ISA audio.
The attachment compaq_2000.jpg is no longer available
The attachment audio.jpg is no longer available
Reply 3235 of 5155, by chrismeyer6
That tape drive looks brand new. My dad had one of those deskpro 2000 systems in his office at work and when he got a new work system he was able to bring it home for me good times.
Reply 3236 of 5155, by Kahenraz
A memory stick I ordered arrived today missing a surface mount component.
The attachment IMG_20210920_045449_resize_10.jpg is no longer available
The attachment IMG_20210920_045440_resize_93.jpg is no longer available
The attachment 2021-09-20 045620_resize_6.jpg is no longer available
Reply 3237 of 5155, by Kahenraz
Remember to test your eBay purchases while they are still within the return window. I bought this cute Rage 128 that ended up being defective.
The attachment IMG_20210920_205509_resize_79.jpg is no longer available
The attachment IMG_20210920_205455_resize_24.jpg is no longer available
The attachment IMG_20210920_205353_resize_99.jpg is no longer available
Reply 3238 of 5155, by HanJammer
Kahenraz wrote on 2021-09-21, 00:57:
Print it on the canvas and it will sell for hundreds if not thousands of dollars 😁
Reply 3239 of 5155, by gerry
good advice as i sometimes leave things untested for a long time, but this is not really found hardware or office cast offs, neighbours free gifts etc - if you put this card into a bin though someone might find it and painstakingly fix it up then post about it! 😀
