Reply 40960 of 58812, by pan069
I got a new PSU for my 286, which sits in a low profile case (is that IPX? Not sure...), anyhow, it's replacing a doggy AT PSU.
However, this is a Seasonic SSP-300SFB 300W 80 Plus Bronze SFX. I haven't tested it yet, I hope it will do. It even came with a SPX to ATX mounting backet (yay!). I have an ATX to AT converter cable that also does -5v, so assume its all going to be okay...
The attachment PXL_20211030_064103328.jpg is no longer available
The attachment PXL_20211030_083004169.jpg is no longer available
The attachment PXL_20211030_083034637.jpg is no longer available
The attachment PXL_20201001_061307745.jpg is no longer available
Reply 40961 of 58812, by CrFr
Finally found a matching monitor for my Aptiva setup. IBM model 6327-022. After cleaning and repairs, it turned out to be really good one. Left hinge for the controls door is broken, but it stays in place when closed. Other than that, it is now near perfect condition.
When I got it, it didn't show any image. Had to replace couple of capacitors and redo some solder joints on the neck board to get it going. VGA connector was crushed, so I had to straighten it. It was very tidy inside, almost no dust at all. It has nice Panasonic tube, that is really bright, colorful and sharp across the screen.
Only thing is, for some reason Aptiva's Creative Graphics Blaster EXXTREME (Permedia 2) won't output anyhing greater than 800x600@85Hz for it. When I was testing the monitor on another machine with S3 Savage4 Pro, it went up to 1280x1024@75Hz.
The attachment IMGP2123_.jpg is no longer available
Reply 40962 of 58812, by pixelatedscraps
CrFr wrote on 2021-10-30, 14:04:
Finally found a matching monitor for my Aptiva setup. IBM model 6327-022. After cleaning and repairs, it turned out to be really […]
That’s a nice looking setup you’ve got there. So many nice, clean, understated IBM desktop units going back so many years. Now if only I had the desk space…
My ultimate dual 440LX / Voodoo2 SLI build
Reply 40963 of 58812, by pixelatedscraps
A bit of a glutton for dual-chip VGA / GPUs - no matter how much they struggled at the time. There’s something haphazard and inelegant about a dual-chip ‘solution’. Needless to say, I must have these quirky, cantankerous beasts.
ATI Rage Fury Maxx. Now to find a stable driver release for both Win98 and 2000.
Reply 40964 of 58812, by brostenen
HanJammer wrote on 2021-10-29, 11:49:
kixs wrote on 2021-10-29, 10:01:
Really guys! Thread about bought items and you're discussing Amiga for pages now!
OK... so... I bought this Amiga accelerator recently...
In the context of it all.... Then. 😁 😁 😁 You cracked me up.
How good is it, and what big box is it for?
Reply 40965 of 58812, by brostenen
Caluser2000 wrote on 2021-10-29, 15:19:
I bought my Amiga A600s.
Nice.... Congrats. It is a little sweet system. Are you planning on upgrading it with something?
Reply 40966 of 58812, by brostenen
Bought a set of Kickstart 3.1 Roms for my Amiga 1200. It turns out that TF-1230 will not work fully with Kick 3.0
It was not mentioned at the sellers product page, and so I found a Cloanto branded version.
The issue with running 3.0 is that the TF-1230 will not automatically add the memory that are onboard.
Speaking of TF-1230, it is a nice piece of hardware.... I also recieved that angled CF-IDE adaptor. Makes it look clean.
The attachment IMG_20211030_182733605.jpg is no longer available
Reply 40967 of 58812, by brostenen
devius wrote on 2021-10-29, 11:24:
Can you move the Amiga discussion somewhere else please?
I will always post images/pictures of any type of hardware that I bought. Even Amiga.
Yes, Piccoline machines as well, if I ever have the money and space for it.
Reply 40968 of 58812, by Caluser2000
brostenen wrote on 2021-10-30, 16:22:
I will keep one stock. The other I intend to up grade when time and funds permit. I was surprised here clear and flicker free the second hand lcd SONY tv was. It's great! No need for scan doublers or any of that no nonsense is need at all. Just hook the A6oo straight up to it. I really am a x86 but when these showed up over a couple of months on or local auction site at an amazingly low "buy it now" price I snapped them up. One previous owner was going back to the UK just wanted to get rid of it. It still has the UK power plug on it and I use an adapter to use on on our power sockets.
Reply 40969 of 58812, by brostenen
Caluser2000 wrote on 2021-10-30, 18:06:
So it is a PAL version? You need one single thing for the 600. That is the relokick disk. It reboot's the 600 into Kick 1.3 for those few pesky titles.
Else it is great that you have an CRT to display the video signal. Personally I am using good speakers for all my vintage computer's.
That is anything Dos, C64 and Amiga, as I find that speakers in tv's and monitors are always crap.
Reply 40970 of 58812, by HanJammer
brostenen wrote on 2021-10-30, 16:21:
It's for Amiga 2000 (pretty much the only one which interests me - I have 3 such systems right now, at one point this year I had 9... One of these 3 is for sale and other 2 will stay with me indefinitely 😉 ). It's 68020@14Mhz so it's not great but not terrible either - around twice as fast as 68000. A2620 is one of the two original Commodore accelerators for A2000 (other one being A2630). It was OE for A2500. It let's you run Amiga Unix - main purpose why I was interested in it. For now I have it in a machine with A2091 SCSI controller and Vortex GoldenGate bridgeboard which I will probably move to the other machine (replacing it with A2088 bridgeboard I have) if I figure out why it doesn't want to boot with it onboard (may be easier than It looks - I havn't moved it with the CPU adapter when I first installed the card in it for tests).
Reply 40971 of 58812, by jm8881
Bought this abit is7 socket 478 for $5 on facebook. It came with a p4 3.0ghz and 512mb ddr. Not a bad deal.
Reply 40972 of 58812, by ODwilly
jm8881 wrote on 2021-10-31, 06:05:
Looks like a killer XP/98 basis. Pretty board
Reply 40973 of 58812, by gex85
Great find, congrats!
Afaik there are no drivers that work reliably for Win2k or Win XP, but I'd be happy to be proven wrong. I have one of these cards in my collection as well.
pixelatedscraps wrote on 2021-10-30, 16:03:
My retro computers
Reply 40974 of 58812, by pixelatedscraps
gex85 wrote on 2021-10-31, 11:12:
Ditto. Anyone with a suggestion / link would be much appreciated!
Reply 40975 of 58812, by jm8881
ODwilly wrote on 2021-10-31, 08:45:
Thanks, I actually replaced the sony vaio motherboard in my xp build with it.
Reply 40976 of 58812, by zapbuzz
jm8881 wrote on 2021-10-31, 15:12:
those sony are quite cheap heh I might remember it when I need a mobo
Reply 40977 of 58812, by appiah4
Ever since the recap of my KT3 Ultra2 failed to resurrect it (and it seems to have killed 2 Socket A CPU's in the process.. Grrr..) I was on the lookout for a universal AGP Socket A board with AthlonXP support. Well, finally I found one for ten bucks. MicroATX, so I can actually build a fairly small and fast Voodoo 3 with it. No idea what CPU it comes with, but beggars can't be choosers.
Reply 40978 of 58812, by BitWrangler
Should be fine if it's got a socketed CPU... I don't think ASRock did it, but ECS did... there were some mATX KT133 boards around with soldered in Morgan Durons 1.1, 1.2, 1.3 and then a couple of years later, same again with applebreds 1.4, 1.6 and 1.8 with I think KN266. Then there was maybe even a third go round with semprons, but unsure if they were socket A or socket 754. They are probably great if you want a win98 system cheap and don't wanna mess with it. But if you're tryna buy something that takes a variety of CPUs you want to avoid them of course. So kind of a PSA, confirm CPU is socketed when buying mATX "Socket A" combos.
Reply 40979 of 58812, by Aublak
More ewaste pickups
Yeah, another Voodoo Rush. This one looks like it'll work too. There's some unpopulated areas for ram. Makes me wonder if I could add some and get an 8mb card. I'd be interested to see if more ram could redeem it's bad reputation.
The attachment IMG_20211101_235622.jpg is no longer available
Creative Voodoo2 12mb. Pins are bent near the pink dot but don't seem broken. Let's hope it works.
The attachment IMG_20211101_235646.jpg is no longer available
A really old WDC i/o card and a memory module for an apple iie.
The attachment IMG_20211102_024356.jpg is no longer available
I actually have an apple iie mobo squirreled away, but I was immediately lost when I realized it won't take ISA cards. I guess it's not as simple to get working as an IBM compat. Maybe if I start collecting apple iie parts, i may be able to get it to work down the road. Or maybe I'm asking too much from luck.
