Reply 41400 of 53023, by TrashPanda
BitWrangler wrote on 2021-12-10, 14:54:I am also in that situation, and found the cables fetch more than a 9800Pro .. wonderful. […]
ChrisK wrote on 2021-12-10, 14:19:The first one unfortunately missing all the connection cables for the AIW 9600Pro making it pretty useless. At least it wasn't that expensive. Didn't test any of it yet.
When I get round to it, I am going to go the route of stuffing jumper wires in the socket and then casting a plug shell around it with hot glue or epoxy and then breaking out at least a single VGA port by trial and error. The only cable pinout online for them is for the version with DVI, maybe that offers clues, maybe it doesn't.
I have seen one for sale on an almost local marketplace, too far to drive, and not sure if seller will ship, which might have the cable with it, and I have been wondering if it's worth the bother/expense to get hold of it just to have the cable to test and get pinout from.
edit: oh wait is yours the DVI version?? Not sure, there were 3 versions of 9600AIW
Im guessing this is a similar setup to the Voodoo3 3500 TV versions with the ugly blue breakout cable ? IIRC the port looks very similar to a DVI port too but is slightly longer.
I remember that the breakout cables for that GPU also go for far more than the 3500 TV GPU itself, must be all the copper in them 😁
