Tillamook 266MHz and working L2 cache?
Reply 380 of 564, by maxtherabbit
Doornkaat wrote on 2022-01-07, 21:20:
maxtherabbit wrote on 2022-01-07, 21:02:
rmay635703 wrote on 2022-01-07, 20:36:
Oh how naive we were
https://www.anandtech.com/show/53
It is because of this that a Pentium MMX-166 can outperform its 200MHz Classic brother.
🤣 what bullshit, imagine thinking a MMX could compare to the God tier Pentium Pro
That quote is about the 166MHz Pentium MMX outperforming the 200MHz Pentium non-MMX though.
yes I'm aware, elsewhere in the article they were talking about how the MMX core was turbo advanced like the PPro
Reply 381 of 564, by Sphere478
I had a chance btw to install two actual tillamooks (previous tests were one mmx, one tillamook) into a dual socket 7 tyan mobo.
The tillamook simply refuses to work in dual. You can post and detect/use one processor only with both installed. Which we already expected, but I thought I’d mention I tried again.
Sphere's PCB projects.
Reply 382 of 564, by Paadam
I stupidly sold one I had few years ago and now they are pretty much disappeared.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 383 of 564, by Sphere478
Paadam wrote on 2022-01-08, 14:30:
For the moment I will keep them in the hopes that some day someone may be able to figure out how to make them do dual.
I wonder if they actually fully removed the function from the core or just from the package? Like, maybe with some micro surgery one could be de lidded and the gold wires attached or something
A dual tillamook would be so awesome
If someone here has a messed up tillamook and could do some investigation on a de lidded unit that would be cool
Reply 384 of 564, by majestyk
When succeeding in getting a dual Tillamook system running you would definitely and literally enter the
"Tillamook_Sphere"!
Reply 385 of 564, by Paadam
Knowing Intel it is disabled in the same manner like locked multiplier (=impossible to undo).
Sphere478 wrote on 2022-01-08, 15:16:
For the moment I will keep them in the hopes that some day someone may be able to figure out how to make them do dual. […]
Reply 386 of 564, by Sphere478
Paadam wrote on 2022-01-08, 19:27:
What method?
Reply 387 of 564, by LeFlash
There are machines out there for manual bonding. But I'm not sure whether you can delid the cpu. It seems that the die is soldered/glued to the silver plate and covered in epoxy from the other side
Edit: seems that deliding is indeed possible, but not sure if there is enough room to access the pads.
Video (trigger warning 😁 )
https://youtu.be/DDNOGX7-FGY
Reply 390 of 564, by GRIFF
Sphere478 wrote on 2021-10-20, 21:16:
You got it to 533mhz?! Woah […]
GRIFF wrote on 2021-08-20, 09:39:
Hello guys. See my result of overclocking this great CPU at march 2020 with enabled L2 cache. https://hwbot.org/submission/43826 […]
Hello guys.
https://hwbot.org/submission/4382631_griff_su … min_54sec_954ms
https://hwbot.org/submission/4382632_griff_wp … min_15sec_271ms
https://hwbot.org/submission/4266296_griff_cp … _266mhz_533_mhz
How high would it go on air cooling?
What bus speed?
Were you limited by bus, memory, or core clock
Yes. And I'm sure is not limit. Next steps is 540mhz, 560mhz and 600mhz.
On air 400-420 MHz is limit for my 5pcs.
Bus 133mhz for 533Mhz of CPU speed.
Reply 391 of 564, by Sphere478
Hey guys, can someone talk to me about the 4x mod. I did the little solder bridge in the picture guide. But on my tyan s1564 I can’t seem to get 4x using any of the ?two? Multiplier pins.
Can someone explain the pull up/pull down procedures, pins and configurations, etc. maybe suggest a way that a third jumper could be added to the cpu it’s self? (Maybe even a removable one)
the_patchelor wrote on 2021-03-03, 16:24:
how I understand: "normal" BF2 mod is just routing BF2 to NC pin, as on Tillamook BF2 Pin is on a different position. […]
how I understand:
for some Boards (at least the P55T2P4's) "Forcing" BF2 is required as without only 3.5x multi boots (=will bot as 233mhz CPU). BF2 can be activated when it will be connected to ground (VSS) or voltage (VCC3) pin.
the P55T2P4's do not have a factory jumper for BF2 (multi >3,5) so e.g. for a AMD K6-300 (4,5) you also have to bridge/mod the socket ...... then I think the normal "BF2" mod (BF2-NC) is enough. But right now I don't wanna have a flying cable or hard modded Board...
Nemo1985 wrote on 2021-03-03, 15:22:
Sorry for the dumb question, so it does work without issues on the P/I-P55T2P4?
Thank you
no issues once you do the 3 bridges on the CPU.
but I only can talk about my version/rev. 3.10
the_patchelor wrote on 2021-03-08, 18:37:
it works if all three are connect and also if only outer two.
Multi jumpers on board are then ignored. you can leave them or set what ever
A few months ago I tried connecting all three, I don’t recall if I used the correct pins though, I may have assumed incorrectly, but whatever I did blew up a resistor on my motherboard which I was able to fix thankfully.
This is mainly why I want a deeper understanding of what is going on here.
I may just take that knowlege and use it for a bf2 socket mod.
And leave the cpu out of it. As I think the 4x works on ss7 boards?
Anyway, if I haven’t mentioned, I tried dual tillamooks finally. What I find interesting is not that they don’t work in dual, it’s that two will actually boot and show one. Which suggests that there is some kind of smp communication going on, because with any other non smp cpu it leads to no post.
Edit: Re: Tillamook SMP mod.
Edit:
Re: Tillamook 266MHz and working L2 cache?
the_patchelor wrote on 2020-09-17, 20:55:
got the Tillamook 266 MMX working at 4x66mhz on a ASUS P/I-XP55T2P4 (ATX Board). Just some headake last night and then I checked some intel documents...
To get multi 4x working, the BF2 has to be "enabled ", so I bridged NC-BF2-Vcc3 and I think this overwrites/enables the missing BF2 support on the Board (or?!)
So this post clearly shows the mod working. With three pins
Is it possible that a short could occur with a configuration like this if you set some of the motherboard jumpers in a specific way? I’m suspecting that instead of a wire we should use a 1k smd there or something?
edit: update on efforts to dual a tillamook have again hit a wall. possibly indefinitely. it seems to be 100% confirmed that several key pins needed for smp are indeed disconnected and basically useless exactly like the tech sheet says.
Reply 392 of 564, by Sphere478
okay I got the 4x working using the extended mod but I jumped over the middle pin, I tried all jumpers on and no shorts, it's still at 4x unfortunately with all jumpers on or off that kinda means that it's stuck in 4x mode.... oh well, I suppose that is okay
any thoughts on how to activate 4.5x or 5x?
I think not connecting to/jumping/skipping over the center pin is safer, it keeps the bf2 pin from even interacting with the mobo it seems. I don't want to investigate further but something about all three pins fried a resistor last time and I don't want to repeat that.
Reply 393 of 564, by Sphere478
Socket 5/7/SS7 (Motherboard) Tweaker (Released)
Some info about the 4x extended mod. It seems the mod should be done via 330 ohm resistor. Not a direct 0 ohm link. Possible magic smoke from that mod.
Reply 394 of 564, by Sphere478
The attachment image.jpg is no longer available
Confirmed working. 330 ohm resistor. 266 mhz on 2x setting on s7 mobo (non ss7)
We need to probably go back and make some edits warning against the previous extended mod.
Edit: I just realized, it may not matter. But only if you skip the center pin.
The center pin to the outer pin is where the danger can come from I believe.
The inner pin is the tillamook bf2 pin
The center pin is the mobo bf2 pin
The outer pin is 3.3v
To make 4x work the inner pin must find 3.3v preferably through a resistor, but it works either way.
If all three are connected, I believe when the center pin is pulled low to ground by mobo jumper setting that it will short to outer pin
Edit2:
I think I thought of a better version of this mod.
330 ohm between outer and middle, 0 ohm between inner and middle
This way the inner is pulled high, and can also be pulled low by mobo.
Reply 396 of 564, by Sphere478
Today I re did the mods on my tillamooks using the new infos.
Two wires,
Two 0-ohm links,
One 330 ohm resistor BF2 to VCC3
I think it turned out good.
I hate how the labels keep coming off the resistors, ugh…
Reply 397 of 564, by Sphere478
The attachment 99FF85AF-848D-4123-A2C0-AAF657C02EE5.png is no longer available
updated the picture guide (OP, feel free to fix my mspaint skills 🤣)
In other news I found a plastic 233 tillamook.
Also,
If a 4.5x multi exists…. What setting would that be? Bf2 pulled low?
Edit:
I’ve been working on a device to solder to the back of the motherboard that should allow all the known socket 5/7/ss7 mods shy of installing a powerleap. And also is designed so that all aspects of the mods can be switched off should you wish.
file.php?id=133207&mode=view
It includes mods for tillamooks.
Reply 398 of 564, by Sphere478
Coming soon to a motherboard near you.
This device will add a bunch of socket tweaks, including the tillamook mods and a way to fully disable them it if needed by flip of a switch,
file.php?id=133892&mode=view
file.php?id=133893&mode=view
Reply 399 of 564, by Paadam
Nice project! Now I need to find a Tillamook again but those are nowhere near as available as few years ago (sadly sold mine few years ago, stupid move).
