Horun wrote on 2022-06-21, 01:09:Yes it is possible to use the ECS Top Hat adapter if you can find one, you still need to program another flash chip with your pr […]
Yes it is possible to use the ECS Top Hat adapter if you can find one, you still need to program another flash chip with your proper BIOS and have it in the Top Hat.
So if you could find one you would need another Winbond W49V002AP that you program with your TL866. One thing I always wondered was how they work since Dual bios boards have a jumper to change between.
The Top Hat must be able to disable the on board BIOS or else it would run in parallel which surely would cause some major issues with diff codes being simultaneously delivered to the data bus 😀
added: Sphere478 you probably could build one, have seen your work in other topics here and it is top notch !
Thank you 😀
Yeah, if you wanna pull together a few datasheets and research it, I can punch out a pcb for you. Just tell me what it needs to do.
That is a particularly perplexing situation though. How one chip could assert dominance over another while in parallel. My guess is there may be a pin for telling the chip to be quiet that is only connected to the lower chip and not the upper. Maybe like a IDE master/slave kinda thing.
In any case, it’s kinda silly to go through this much effort when the tools you need to make such a device would also allow you to just fix the chip its self without said device.
Is this what you are talking about?
In theory if that whole master slave thing works like I think it does, you could sinply leave it there if you wanted. Or do a hot flash with it. Boot the system, pull it, run the flash utility.
Edit: datasheet
https://html.alldatasheet.com/html-pdf/86965/ … /W49V002AP.html
