Reply 22680 of 31852, by Sombrero
svfn wrote on 2022-09-17, 17:39:
Focus G is always a nice choice for retro builds if you want more airflow haha. Now they've also released Pop Air with 2x 5.25" bays but these cases feel big in terms of footprint.
I got myself Pop Mini Silent and my only complaints are that the door for the 5.25" bay is just a magnetic cover that comes off completely instead of being an actual door with hinges, can be kinda annoying to mess with the cover if you need access to the 5.25" drives frequently enough.
That and the paint is a fingerprint magnet. Otherwise I'm very happy with it. Wouldn't use it for high power system though, it won't be able to cool some modern 500W+ TDP monster but it's great for my ~220W Haswell rig.
Reply 22681 of 31852, by Shponglefan
I do like the size of the Focus G cases. Perfect for full sized ATX without being gigantic like some modern cases.
The Pop Air cases look really awesome, although I'm not completely sold on the placement of the 5.25 bays in it.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 22682 of 31852, by svfn
Yeah some said the 5.25" bay with the cover off looks ugly. Tbh I am not sure why Fractal added a new line with 5.25" bays and removed bays from the Focus G line. Also I just feel uncomfortable with tempered glass, acrylic is fine for me as my nails are short and a few scratches are not that bad.
SS7: K6-2/350 | FIC PA-2013 2.1 | 32MB PC-100 | 3dfx V3 2000 AGP | AWE64 CT4520 | Win98SE
On MobyGames
Reply 22683 of 31852, by Giuliano
PD2JK wrote on 2022-09-15, 16:53:
Commodore 386SX-16 took a vinegar bath. It had some nasty battery goo. Yes, it got revived! Two long beeps + three short beeps. I think it needs a battery.
Hi @PD2JK, I didn't know about this method of cleaning a board with a vinegar bath. What kind of vinegar or mixture do you use? And for how many minutes?
Cheers
Reply 22684 of 31852, by Sombrero
Shponglefan wrote on 2022-09-17, 18:13:
If the case is on a table or something it's fine, no problems. If the case is on the floor it's AWFUL, I wouldn't recommend these cases for anyone who need 5.25" drives and would have to keep the case on the floor. I've got mine sitting on top of Fractal Design Define R4.
svfn wrote on 2022-09-17, 18:16:
It does look ugly, I always slap the cover right back once I'm done with the dvd drive.
Reply 22685 of 31852, by GuillermoXT
Shponglefan wrote on 2022-09-17, 17:34:
Transplanted my Windows 98 build into its new case, a Fractal Designs Focus G.
Next on the list is adding an Audigy 2 ZS alongside the current Diamond Monster MX300.
Looks really clean for a Win98 build 🙂👍
My setup compared to that looks a bit messy inside but using a GA-6BA (Baby AT) with a P3 Coppermine I'm ok with that 😅
The attachment 16634412969945650594968564831346.jpg is no longer available
My Retrosystems:
PIII on GA-6BA running Win98SE
AMD K6 233 on GA-586HX with Win95
Tandon 286-8MHZ Running DOS 6.22 on XTIDE-CF
M326 486DLC + 4c87dlc (Dos+Win3.11)
ECS UM4980 AMD DX2 80 5V (Dos & Win3.11)
Reply 22686 of 31852, by RiverBoa
Keeping the dream alive, shopping for a faster VLB card for my 486 rig. I also had a very generous person hook me up with a mouse systems mousepad that would work with a PCjr optical mouse. It works better than I expected and is so odd to think it was from 1984.
Reply 22687 of 31852, by Shponglefan
Sombrero wrote on 2022-09-17, 18:38:
I keep mine of the floor, so I think I'll stay with the Focus G cases for now. 😀
GuillermoXT wrote on 2022-09-17, 19:04:
Thank you! It came with a window, so I feel extra obligated to tidy up those cables. 😉
Reply 22688 of 31852, by rkurbatov
Cleaned an old AT PSU. Painted it black, as it will be installed in unusual case with black chassis (though white front panel and that П shaped cover).
Installed a new cooler, had to add a resistor - it's powerful but loud. And all of that pain for 25-30 years old stuff, to run it several times and forget 😀
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 22689 of 31852, by Lylat1an
Today I dropped off my Retro Rig's motherboard a few of its expansion cards to be recapped.
Reply 22690 of 31852, by PD2JK
Giuliano wrote on 2022-09-17, 18:25:
Cheers
Hey Giuliano, I used a cardboard box with same dimensions of the mainboard, put a plastic bag in it so it won't leak. Then I used 100% cleaning vinegar and let it soak for an hour. I also used a toothbrush to get the green leaky stuff off. Don't use your own everyday use toothbrush.
After that I rinsed the board with demineralized water and dried it with my hot air station. You can also use a hair dryer or heat gun. I still have to paint the traces with some clear nail polish to protect them against new corrosion...
has all kinds of stuff
Reply 22691 of 31852, by Shponglefan
Spent the last 3-4 hours trying to get a compact flash card setup and booting on my Tandy 1000 HX. I have the 3-in-1 PCB add-on which includes extra RAM, a serial port and CF adapter.
This ended up not being a straight-forward process.
First, creating bootable 720kb disks was a challenge. I tried several different applications. FDImage could create 720kb floppies that would read on the Tandy 1000, but for some reason they wouldn't boot. Rawwrite and rawrite proved useless entirely. Finally using WinImage I was able to successfully create disks that would boot on the Tandy.
Then came partitioning and formatting. I'm using a 32MB CF card. I wiped the card on my Windows 10 machine using AOEMI Partition Assistant.
Initially I tried using MS-DOS 3.3 to partition and format the CF card. Unfortunately while the CF card was formatted and usable, I could not get DOS to boot from the card.
One card wipe later, I switched to MS-DOS 5.0 and success! Finally it was booting from the CF card.
I then reconnected the CF card to my Windows 10 machine. It initially wouldn't show up until I assigned a drive letter with AOEMI Partition Assistant. Once that was done, I could read/write to the CF card in Windows 10, flip it over to the Tandy 1000, boot up and play those games.
It turns out that proper disk imaging software (WinImage) and appropriate DOS version (5.0) is critical to getting everything to work.
Now to enjoy some classic Sierra games with their glorious 3-channel Tandy sound. 😁
Reply 22692 of 31852, by timsdf
I can recommend a fan to blow air for GPU ram chips. Zalman is a good cooler but chips/vrm below cooks very easily on ti4600 / 9800pro in my experience. Originally Zalman came with a 60mm fan mount on the side with some models.
Your case front 120mm may be just enough though. Maybe I'm being paranoid 😁
Reply 22693 of 31852, by grint
Tried to install Notepad++ on the Windows 98 instance I set up yesterday, using DOSBox-x. Tried several versions, with very little luck. Even the ones that would start up mysteriously refused to open or save a file.
Reply 22694 of 31852, by Shponglefan
timsdf wrote on 2022-09-18, 19:59:
This particular card is a Ti4200, which does have lower memory clock speed compared to the Ti4600. So maybe it doesn't run as hot?
I suppose the best solution would be adding some additional heatsinks directly on the memory chips.
I'm also hoping the general air flow (dual 120mm intake and 120mm exhaust) will give it enough airflow. Certainly more than typical cases from back in the 90s.
Reply 22695 of 31852, by timsdf
Shponglefan wrote on 2022-09-18, 20:24:
This particular card is a Ti4200, which does have lower memory clock speed compared to the Ti4600. So maybe it doesn't run as ho […]
It's probably fine with 120mm fan blowing from distance and older TSOP large ram chips. Nice build and way more quiet than a card with stock heatsink 😁
Reply 22696 of 31852, by rkurbatov
Desoldered dead battery Dallas RTC from Pentium motherboard. Oh my, spent all evening on that. Surprised, motherboard still alive.
I'm still waiting for details for Necroware RTC module - I ordered wrong ICs - they are in much smaller formfactor than required by PCB. So put another Dallas from AliExpress in the socket - seems working.
Reply 22697 of 31852, by Shponglefan
Started working on another Tandy I own, a model TL/2 I bought awhile ago but hadn't tested.
Oddly didn't work with my CM-11 monitor for some reason (garbled output), but worked fine with this old Packard Bell CGA monitor I had. I assumed it should be compatible with the CM-11 monitor since I've seen photos of TL/2's running on them? Or is there some settings that need to be configured somehow?
At any rate, the machine seemed to work, including the 3.5 inch drive.
I have a CF adapter and memory expansion board I may try in this one. I do lack a proper Tandy Enhanced Keyboard, so I'll have to try to pick one up.
Reply 22698 of 31852, by bjwil1991
There might be a DIP switch or jumper block that got set to CGA 80 mode instead of TGA mode and it's either in the back of the computer or inside on the motherboard.
I flashed a modified BIOS for my Austin M1RC and it works (I archived the original to be safe) and I flashed a MR BIOS set for a 286 board I'm going to test later on tonight.
I have yet to get that ECS 286 LX-A working and if the MR BIOS boots up, then I know for a fact that the original ROMs have gone bad or just a fluke somewhere. No battery damage since the board was never used and I have another 286 board I can test out as well which uses SIMM-30 RAM and there isn't a spot for PDIP RAM (late 286 board).
Reply 22699 of 31852, by Radical Vision
Not really retro, but old activity..
Installed the stock coolers of my R9 280x VaporX and R9 280x Toxic, they had missing fans and shrouds, so when is aw local ADs i did purchase dead cards, but with well working fans, to install on my cards, and making them as they should be. I even managed to revive the artifacting VaporX, and did buy another cooler for it, so i have now extra VaporX, that will be sold, the card is working great did test it multiple days for like 2 hours per day, and no crashes, artifacting or any crap going on..
Did install also X-Fi Xtreme music to the x58 system, the card works great, no craclikng, buggy sound or anything. I think that card did even improve the performance in Prototype II and GTA V, since before installing it, the games did run well, but there was some sort of microsttuter, now with the X-Fi there is not. The interesting part is that, this is the Music card, not the Gamer or Fatal1ty, as they have more memory for gaming. Some ppl did state that this memory on these X-Fi cards is BS, but it appers, that they improve the performance of the sound, and with that the games run smoother as well...
This is how the cards did look before adding the factory fans and shroud...
The attachment 20211228_122506.jpg is no longer available
The attachment 20211228_122448.jpg is no longer available
The attachment 20220328_103409.jpg is no longer available
The attachment 20220918_205650.jpg is no longer available
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
