First post, by GunKneeNeon
- Member
I have a Pentium I retro PC. The specs is as follows:
The mainboard has 3 ISA slots and 2 PCI slots. I want to use 4 of them (2 ISAs, 2 PCIs). The 2 PCI slots are limited to IRQ 10-11, no other channel can be assigned to them. Here is the issue: IRQ11 cannot be used by either the NIC or the sound card, even if there are no ISA devices presents. I tested it with a S3Trio64V+ PCI graphic card out of curiosity and it worked with IRQ11. In order to use the 2 PCI devices, I have to let them share the same IRQ, namely IRQ10. However, I really want to figure out why IRQ11 cannot be used except a graphic card. I thought it was the BIOS and tried to find a way to flash it, but Awdflash failed to do that. It cannot backup my BIOS correctly, so it's very dangerious to flash it without a backup.
When the ISA devices are there, the issue becomes even worse. Whenever the MPEG card is used, both IRQ10 and IRQ11 are unusable. Again, except the graphic card. I don't have the driver for the MPEG card and have no way of assigning the IRQ for it. There is no jumper on the card that can be used to set the IRQ either.
Now the situations are:
So the questions here are:
1. What causes IRQ11 unusable?
2. Why the presence of the MPEG card makes PCI devices to fail? Maybe it uses IRQ10 by default? If that is the case, the PCI graphic card should not work too.
3. How can I achive the optimium situation?
Any help is appriciated! Thanks in advance!
EDIT: Oops! The space characters cannot be shown here, so I have to use pictures instead.
Oh, I forgot to mention: The "PCI IRQ Actived By" option in BIOS cannot be set to "Level" when there is any ISA device. Or the boot process will hang after the IDE channel testing. Why is that?
