First post, by GunKneeNeon
I have a Pentium I retro PC. The specs is as follows:
The attachment 1.JPG is no longer available
The mainboard has 3 ISA slots and 2 PCI slots. I want to use 4 of them (2 ISAs, 2 PCIs). The 2 PCI slots are limited to IRQ 10-11, no other channel can be assigned to them. Here is the issue: IRQ11 cannot be used by either the NIC or the sound card, even if there are no ISA devices presents. I tested it with a S3Trio64V+ PCI graphic card out of curiosity and it worked with IRQ11. In order to use the 2 PCI devices, I have to let them share the same IRQ, namely IRQ10. However, I really want to figure out why IRQ11 cannot be used except a graphic card. I thought it was the BIOS and tried to find a way to flash it, but Awdflash failed to do that. It cannot backup my BIOS correctly, so it's very dangerious to flash it without a backup.
When the ISA devices are there, the issue becomes even worse. Whenever the MPEG card is used, both IRQ10 and IRQ11 are unusable. Again, except the graphic card. I don't have the driver for the MPEG card and have no way of assigning the IRQ for it. There is no jumper on the card that can be used to set the IRQ either.
Now the situations are:
The attachment 2.JPG is no longer available
So the questions here are:
1. What causes IRQ11 unusable?
2. Why the presence of the MPEG card makes PCI devices to fail? Maybe it uses IRQ10 by default? If that is the case, the PCI graphic card should not work too.
3. How can I achive the optimium situation?
Any help is appriciated! Thanks in advance!
EDIT: Oops! The space characters cannot be shown here, so I have to use pictures instead.
Oh, I forgot to mention: The "PCI IRQ Actived By" option in BIOS cannot be set to "Level" when there is any ISA device. Or the boot process will hang after the IDE channel testing. Why is that?
The attachment 3.JPG is no longer available
Constantly looking for the driver for Acer Magic v1 MPEG decoding card.
Reply 2 of 13, by Rwolf
Not sure how the interrupt controllers work on that board, but ISA always uses edge-triggered interrupts, that is how the bus was designed;
one nice thing with the PCI bus is the level-triggered interrupts, which allowed sharing them. If you have multiple interrupt controllers,
each controller could have its own configuration in that respect, but maybe that chipset only allows one common configuration for all IRQ/INT lines?
Why IRQ11 is not working, I don't know...maybe the physical connection is bad, and the video card is not actually needing any IRQ/INT line?
Reply 3 of 13, by GunKneeNeon
Rwolf wrote on 2023-05-25, 09:56:
This is very informative, thanks!
... and the video card is not actually needing any IRQ/INT line?
Yes, you are right. The video card doesn't really need an IRQ. There is option in BIOS called "Assign IRQ For VGA". When set to "disabled", the video card(the PCI one)'s IRQ value becomes NA under the "PCI device listing...." table during system boot up. I've managed to update the BIOS to a new version and the old one didn't show the correct information. It would show 10/11 instead of NA. However, the update broke the ps/2 mouse support. The system, both Windows and DOS, cannot detect my ps/2 mouse now. I think I have to flash the previous version back if no other version could be found.
Reply 5 of 13, by Rwolf
PS/2 mouse should have IRQ12, what I recall. Do you have a PS/2 keyboard as well?
If the test bios actually turned off the mouse port, a cable splitter from the keyboard port might work.
Reply 7 of 13, by Rwolf
Hmm...it would go from one of the board chips yes.
If you look at https://pinoutguide.com/Slots/PCI_pinout.shtml
you will find the pins for INT A/B/C/D which are the names for the interrupt lines on the connectors, and each interrupt should be connected in parallel to all the PCI connectors on the board - you had two PCI slots.
These INT lines are mapped in the interrupt controller to whatever IRQ number you want to actually use.
On the older mixed ISA/PCI motherboards these were sometimes mapped with jumpers, but your board is a newer one, unless I misread some info online.
Anyway, it should go somewhere to the chip containing the interrupt controller - which I'm not sure which one it is, we need a manual for the chipset for that; maybe it is possible to find somewhere.
Edit: The chipset is Cx5510 according to an archived polish test page I found: https://www.chip.pl/1998/08/maly-moze-niewiele
Block diagram: https://www.pctechguide.com/cyrix-cpus/cyrix-mediagx
More details: https://halfhill.com/byte/1998-2_cover_system.html
Less interesting perhaps, details from the release: https://www.ardent-tool.com/CPU/docs/MPR/110301.pdf
It looks like the pins are accessible for probing on the bridge chip, being a quad flat pack, so it should be possible to verify an electrical connection with a simple resistance tester.
Reply 8 of 13, by GunKneeNeon
Rwolf wrote on 2023-05-26, 13:28:
This is beyond my knowledge for now, but I do have the plan to learn hardware in the future.
However, your suggestion remind me of something. The south bridge chip of my modern laptop did fail 2 years ago and the repair technician fixed the machine by replacing the chip. Physical connections doesn't break very often but the chip itself kind of does. Maybe I should replace the chip to fix the IRQ11 issue. That's not possible to do by myself.
Reply 9 of 13, by Rwolf
It is not trivial to replace a QFP package like that bridge, and I would rather suggest to find another working motherboard if that was the problem.
Maybe someone else has an identical motherboard to compare with?
Reply 10 of 13, by GunKneeNeon
Rwolf wrote on 2023-05-27, 23:19:
I think I have to live with it for now. I suspect the failure may have something to do with this NIC. I installed it before, the problem with it is that when plugged by an ethernet cable, my pc wouldn't boot. If the cable was plugged when Windows was running, it simply froze the system. By default, the BIOS always assigns IRQ11 to network adapters. Maybe the presence of this doggy NIC burnt out the chip, though I'm not sure about it.
The attachment nic.jpg is no longer available
Reply 11 of 13, by Rwolf
Hard to tell...could be something is shorted on the NIC that affected that specific INT line. (Hard to see with this picture, but maybe check for near pins shorted on that QFP package; there could be something there. Most likely not...with a lockup on cable attachment, the problem is possibly closer to the connector side - did it release the lockup when disconnecting the cable, without a reboot?) (Looks like a clone version of the Realtek RTL8139D chip, so an equivalent card would be possible to find)
The board is partially populated at the transformer, but that is probably to save on cost with some unused RJ pins, nothing obvious, except perhaps the missing safety cap that is normally close by the RJ connector.
Even if the bridge INT port was damaged, the IRQ11 itself should be mappable in the BIOS to another physical INT line, and usable in any other slot, if just a single line/slot was affected.
Reply 12 of 13, by GunKneeNeon
Rwolf wrote on 2023-05-28, 13:15:
No.
This thingy was literally a cheap one, probably less than $2 USD when bought. And yes, I found the cap you mentioned on a similar RTL3194D card.
I'm not very familiar with the INT# settings. The only related one in my BIOS settings is the one in the picture. It seems to be related only with PCI IDE controller or something like that, rather than a general PCI IRQ setting.
The attachment PCI IDE.jpg is no longer available
Reply 13 of 13, by Rwolf
Well the IDE controllers have IRQ 14/15 normally - these controllers are usually both on your motherboard as seen in the block diagrams as the EIDE controller, so only in case of the use of a separate IDE controller on the PCI bus would you need to map it like the last image you posted as just an example, I understand.
(In such a case the INT line A will use IRQ14 and INT line B will use IRQ15 - they could be used in the same PCI slot if the controller card has two IDE buses.)
To manually adjust more detailed mapping would probably need another BIOS, as you have already tried.
