ATC-5200 + k6-2+
Reply 20 of 53, by Chkcpu
Hi brunofbrsilva,
The K6-2+ is a Dual voltage CPU, just like the regular K6-2.
Single Voltage CPUs like the original Pentium, the AMD K5, and the IDT Winchip C6, use the same voltage for Vi/o and Vcore. For Dual Voltage CPUs, Vi/o and Vcore are different. This motherboard supports both Single and Dual voltage CPUs but you have to set the JP1 jumpers for Single Voltage mode or Dual Voltage mode yourself, depending on the installed CPU.
In Dual Voltage mode, the board will keep Vi/o at 3.3V while the SW2 setting controls the Vcore.
So use the K6-2 setting for JP1: 1-3 close and 2-4 close (Dual Voltage mode) for your K6-2+.
See page 15 of the manual: https://theretroweb.com/motherboard/manual/52 … 67648865314.pdf
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 22 of 53, by brunofbrsilva
Good evening everyone, I tried to update the BIOS, but the program returned the following message: "the Program file's part number does not match the tour system!", I am using awdflash version 8.65 in the BIOS file 5200108.bin and 5200v106.bin also
Reply 23 of 53, by Sphere478
Are you sure you have the correct bios?
Try uniflash
Sphere's PCB projects.
Reply 27 of 53, by Sphere478
Corner with notch, middle pin. Use a resistor leg with no cpu. Measure to gnd/case/black
Reply 29 of 53, by Sphere478
Perfect! 😀
Reply 30 of 53, by brunofbrsilva
good morning friends, starting work here, I am confused with the double voltage jumpers, the manual says that it should be 1-3 closed and 2-4 closed, I am sending a photo for friends to analyze if it is correct
554.51 KiB
Reply 31 of 53, by Nexxen
brunofbrsilva wrote on 2023-07-08, 12:23:
Looks correct to me.
1-2
3-4
5-6
Closed: jumper over 1-3 and 2-4 like in picture.
If you are getting 2.0V it means it is correct indeed otherwise it'd be 3.3V.
This "friend" thing is starting to sound like Mr. Robot 😀
Bruno, you aren't planning to hack into E-Corp with this K6?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 33 of 53, by brunofbrsilva
windows started !!!!!! do i have to monitor something? if yes how?
1.5 MiB
Obs: On Everest it shows k6-2+ 550 and on windows it shows k6(tm) lll
Reply 36 of 53, by Chkcpu
brunofbrsilva wrote on 2023-07-08, 19:17:
Guys, so far everything normal, I've run some games and even used setmul on it, I would like to thank everyone who could help me you are the best. thanks
You’re welcome. 😀
But still one question though: What is the voltage regulator chip on this ATC-5200 board? With this knowledge I should be able to make a SW2 table with all available Vcore settings so I can help other people with this board.
Thanks, Jan
Reply 38 of 53, by Chkcpu
That would be the little chip between the first ISA slot and the corner of the CPU socket.
