ATC-5200 + k6-2+
Reply 20 of 53, by Chkcpu
Hi brunofbrsilva,
The K6-2+ is a Dual voltage CPU, just like the regular K6-2.
Single Voltage CPUs like the original Pentium, the AMD K5, and the IDT Winchip C6, use the same voltage for Vi/o and Vcore. For Dual Voltage CPUs, Vi/o and Vcore are different. This motherboard supports both Single and Dual voltage CPUs but you have to set the JP1 jumpers for Single Voltage mode or Dual Voltage mode yourself, depending on the installed CPU.
In Dual Voltage mode, the board will keep Vi/o at 3.3V while the SW2 setting controls the Vcore.
So use the K6-2 setting for JP1: 1-3 close and 2-4 close (Dual Voltage mode) for your K6-2+.
See page 15 of the manual: https://theretroweb.com/motherboard/manual/52 … 67648865314.pdf
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 21 of 53, by brunofbrsilva
Perfect my friend, thank you very much for the explanation, this process has been a lesson for me, I thank everyone here in the group for helping me
Reply 22 of 53, by brunofbrsilva
Good evening everyone, I tried to update the BIOS, but the program returned the following message: "the Program file's part number does not match the tour system!", I am using awdflash version 8.65 in the BIOS file 5200108.bin and 5200v106.bin also
Reply 24 of 53, by brunofbrsilva
I used the link that the friend gave me above for version 1, I'll try with uniflash
Reply 25 of 53, by brunofbrsilva
It worked guys BIOS updated !!!!!
Reply 26 of 53, by brunofbrsilva
now i have to measure the vcore voltage directly on the socket does anyone have any idea which pin i can measure?
Reply 28 of 53, by brunofbrsilva
I didn't change anything, I just removed the processor and measured it, to my surprise it's showing 1.99 - 2.00.
Obs: I tested it with another multimeter with a new battery, it gave 2.01
Reply 30 of 53, by brunofbrsilva
good morning friends, starting work here, I am confused with the double voltage jumpers, the manual says that it should be 1-3 closed and 2-4 closed, I am sending a photo for friends to analyze if it is correct
The attachment Screenshot_20230708-092210.png is no longer available
Reply 31 of 53, by Nexxen
brunofbrsilva wrote on 2023-07-08, 12:23:
Looks correct to me.
1-2
3-4
5-6
Closed: jumper over 1-3 and 2-4 like in picture.
If you are getting 2.0V it means it is correct indeed otherwise it'd be 3.3V.
This "friend" thing is starting to sound like Mr. Robot 😀
Bruno, you aren't planning to hack into E-Corp with this K6?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 32 of 53, by brunofbrsilva
hahahahahahahahha I'm Brazilian and my English is not 100% so I try to be as cordial as possible, but yes e-corp will fall kkkkkkkkkkkk
Reply 33 of 53, by brunofbrsilva
windows started !!!!!! do i have to monitor something? if yes how?
The attachment 16888233474957954871075980293231.jpg is no longer available
Obs: On Everest it shows k6-2+ 550 and on windows it shows k6(tm) lll
Reply 34 of 53, by Nexxen
CPU-Z Windows 98 version.
Should identify correctly.
Reply 35 of 53, by brunofbrsilva
Guys, so far everything normal, I've run some games and even used setmul on it, I would like to thank everyone who could help me you are the best. thanks
Reply 36 of 53, by Chkcpu
brunofbrsilva wrote on 2023-07-08, 19:17:
You’re welcome. 😀
But still one question though: What is the voltage regulator chip on this ATC-5200 board? With this knowledge I should be able to make a SW2 table with all available Vcore settings so I can help other people with this board.
Thanks, Jan
Reply 37 of 53, by brunofbrsilva
I'm sorry I just forgot, which chip do you believe it could be? I'll take a picture of him if you want.
Reply 39 of 53, by brunofbrsilva
See if this is correct:
The attachment IMG-20230708-WA0815.jpg is no longer available
