First post, by egbertjan
Which s3 virge DX driver should I use under Windows 98 SE. I am now using the standard that comes with Windows 98 SE. The PC crashes during the race in 3dmark 99 and also when I do the direct 3d test in dxdiag. This all works if I do this with the voodoo 2 card in the same PC. The drivers I can find on the internet for the s3 virge dx are all for Windows 95 and older than the standard Windows 98 SE driver. Which driver do I need to solve this problem in Windows 98 SE. I tried this on different s3 virge dx cards all 4MB memory.
Can an s3 virge dx 4mb even run 3dmark 99?
Reply 1 of 3, by Gmlb256
Try these: https://archive.org/details/s3-virge-dx-gx-gx2-win9x-driver. Drivers written for Windows 95 should work fine in Windows 98 and the ones that you're currently using aren't necessarily "newer" despite the date.
BTW, just use the Voodoo2 for 3D stuff. All S3 ViRGE cards aren't ideal for these except S3D and certain early D3D ones.
Reply 3 of 3, by aaronkatrini
From my testings the Virge/DX cannot run 3Dmark99, you can use Final Reality (on board accelerator) if you want to test the card.
