The Soundblaster DSP project
Reply 500 of 1053, by mattw
Maelgrum wrote on 2023-10-04, 03:42:
Changes:
Must leave card in more sane state.
tested on 4x CT4170 cards, on all of them I get the following log:
SB Reset: done
DSP version: 4.16
MPU-401 init: done
MPU-401 loopback check: done
ADDR1: 0A66
ADDR2: 0498
ADDR3: 0C17
Success!
Reply 501 of 1053, by mattw
is it possible based on those values difference to adjust the offsets between know version attack and unknown one, I mean:
(V413) - (V416)
0B31 - 0A66 = CB
0555 - 0498 = BD
0DBF - 0C17 = 1A8
or it's a total nonsense?
Reply 502 of 1053, by S95Sedan
Changes:
Tried all sort of things here on the 4.11 card but i couldnt get the loopback working.
Mostly due to not wanting to blow up the card as it supplies voltage on the db62 connector.
(directly on the joystick didnt work, cable loopback didnt work either)
Heres the stuff for the 4.12 one though;
SB Reset: done
DSP version: 4.12
MPU-401 init: done
ADDR1: 0B3F
ADDR2: 054F
ADDR3: 0DBF
Success!
Reply 503 of 1053, by Maelgrum
mattw wrote on 2023-10-04, 04:23:
tested on 4x CT4170 cards, on all of them I get the following log: […]
Changes:
SB Reset: done
DSP version: 4.16
MPU-401 init: done
ADDR1: 0A66
ADDR2: 0498
ADDR3: 0C17
Success!
Excellent !
This information will be used at next stages.
ADDR1 is address inside F9 command. ADDR2 is address of main command loop.
Next stage will be evaluation of possible injection vectors.
In MPU loop, stack will be:
C4 - 0C <- here we inject values from 0 to 3
C3 - 17
C2 - 04 <- here we inject values from 0 to 3
C1 - 98
C0
And memory at location 0xC0 and below fill be filled with 0x00, so after some code execution in interrupt handler, RETI will direct execution flow to address 0x0000 - Reset handler
After reset, fw outputs byte 0xAA to data port
So we will try to jump to address 0x0098, 0x0198, 0x0298, 0x0398, 0x0017, 0x0117,0x0217,0x0317, and see what happens
If SB hangs - its bad vector
If AA is in data port - its indication of possible good vector
This is stage 1
Reply 504 of 1053, by Maelgrum
S95Sedan wrote on 2023-10-04, 04:43:
Tried all sort of things here on the 4.11 card but i couldnt get the loopback working. Mostly due to not wanting to blow up the […]
Changes:
SB Reset: done
DSP version: 4.12
MPU-401 init: done
ADDR1: 0B3F
ADDR2: 054F
ADDR3: 0DBF
Success!
Thanks S95Sedan !
Reply 506 of 1053, by Maelgrum
mattw wrote on 2023-10-04, 05:07:
Maelgrum wrote on 2023-10-04, 04:57:
This is stage 1
sounds very promising and 4 addresses for 2 locations - it's not that many tries to see which one are potentially good.
It is only stage 1 to discard definitely bad variants.
Stage 2 will be more complex:
To determine stack structure for potentially good variants.
We already determined code position ADDR1 of read memory command.
So by bruteforcing, we can try to jump to this location.
So we try variants of stack structure:
C0 - 0A
BF - 66
then:
C0 - 0
BF - 0A
BE - 66
and so on, rolling down, on some reasonable range, until we get something from SB data port (not 0xAA)
repeat for all potentially good variants of injection
This is Stage 2. We determined where return address is placed on stack for each injection variant
Reply 507 of 1053, by aitotat
Maelgrum wrote on 2023-10-03, 16:19:
Ultimate goal is to crack and dump 4.16. It fixes single cycle dma bug, and I think it may work on older SB/AWEs.
But does it really fix the single cycle DMA bug? Vibras don't have it and if they use the same v4.13 DSP, then the single cycle DMA bug is likely not a DSP bug but some hardware bug elsewhere. But hopefully some workaround hack can be made to the DSP code.
Reply 508 of 1053, by Maelgrum
aitotat wrote on 2023-10-04, 05:31:
you won't know until you try ))
Reply 509 of 1053, by LSS10999
mattw wrote on 2023-10-03, 17:10:
that's kind off-topic here, but probably just custom-modified card by someone and then it was sold and ended up with you, because 5 years ago it was posted here "I de-CQMed my AWE32 PnP CT3990...!":
and such modification became popular among the retro-community, i.e. how to replace CQM with YMF289B on SB cards that have (unpopulated) pads for both those chips. I myself ordered back then all the necessary chips, but I did not actually do it...
Thanks for pointing to the thread. The post you mentioned showed greater detail about how to make cards use YMF289B instead of CQM.
mattw wrote on 2023-10-03, 17:39:
I am 99% sure that @LSS10999 card was modified by someone and it's not manufactured like that by Creative, but in any way, it doesn't really matter as such modification is possible both ways and thus this off-topic is now settled.
I got my card a long time ago (long before that thread existed), and it was already like that -- having YMF289B instead of CQM. I couldn't find any trace of modifications... but it doesn't matter anyway.
The original question that led to this off-topic was about how the DSP would know whether there's a CQM or a real OPL (YMF289B in this case). I think the answer to it is also there from what I've read.
Still, I'm looking forward to seeing a proper dump of 4.16 FW.
Reply 510 of 1053, by Maelgrum
sbcrack Stage 1
This is definitely not safe software, use with clear understanding of risks.
Reply 511 of 1053, by mattw
Maelgrum wrote on 2023-10-04, 06:22:
sbcrack Stage 1
3 options failed, 5 still are potentially good:
SB Reset: done
DSP version: 4.16
MPU-401 init: done
Stage 1, variant 0 ...passed
Stage 1, variant 1 ...failed
Stage 1, variant 2 ...passed
Stage 1, variant 3 ...failed
Stage 1, variant 4 ...passed
Stage 1, variant 5 ...failed
Stage 1, variant 6 ...passed
Stage 1, variant 7 ...passed
Success!
Reply 512 of 1053, by Maelgrum
sbcrack Stage 2
Reply 513 of 1053, by mattw
Maelgrum wrote on 2023-10-04, 10:17:
sbcrack Stage 2
only 3 passed "variants" remained, full log attached:
Stage 2, variant 4 ...passed
Stage 2, variant 18 ...passed
Stage 2, variant 39 ...passed
    STAGE2_V416_LOG.TXT
    2.04 KiB
    29 downloads
Reply 514 of 1053, by Maelgrum
mattw wrote on 2023-10-04, 10:29:
only 3 passed "variants" remained, full log attached: […]
sbcrack Stage 2
All 3 variants look good,
Variant 39 is most usable, with probable stack stucture:
0xC0 R0
0xBF DPH
0xBE DPL
0xBD ACC
0xBC PCH
0xBA PCL
Reply 515 of 1053, by Maelgrum
sbcrack Stage 3
Validation of variant 39
Reply 516 of 1053, by S95Sedan
sbcrack Stage 1
Heres for the 4.12 one;
SB Reset: done
DSP version: 4.12
MPU-401 init: done
Stage 1, variant 0 ...failed
Stage 1, variant 5 ...passed
Stage 1, variant 6 ...failed
Success!
Reply 517 of 1053, by Maelgrum
S95Sedan wrote on 2023-10-04, 11:31:
Heres for the 4.12 one; […]
sbcrack Stage 1
SB Reset: done
DSP version: 4.12
MPU-401 init: done
Success!
Please don't try other stages - it's 4.16 specific.
Stage 1 is common
Reply 519 of 1053, by mattw
mattw wrote on 2023-10-04, 11:37:
stage3 for V4.16 is coming in minutes...
looks good, here is the log:
SB Reset: done
DSP version: 4.16
MPU-401 init: done
Stage 3, variant 39 ...passed
Success!
