Sphere478 wrote on 2023-12-19, 02:02:
I've been throwing around the idea of making a socket 370 build that would be actually mid 2000's era gamable and maybe even play some late 2000s titles at low settings.
I'm going to assume that such a contraption would be based on dual p3 1.4ghz 512k chips. (were there any faster chips? xeons? I don't think there were.. via 1.6 would be slower I assume?)
Yea, the 1.4T's are pretty much the best you can get until the Socket 603/604 era.
if I recall correctly there were some late p3 mobos with ddr support right? any that had agp?
I think there was one board that had ddr and dual P3. without going through a lot of searching the Asus CUV266-DLS comes to mind.
I assume 4gb of ram might be doable?
AFAIK only on the true-blue server chipsets. I know the ServerWorks ones are capable of 8gb. 2000 server and XP will see the ram, but you should do some research into PAE. https://learn.microsoft.com/en-us/windows/win … dress-extension
hard drive, obv, a 64-bit pcix sata to m.2 sata is in order.
Sounds about right.
OS... maybe win 2k? or would winxp/7 be any advantage?
XP is just 2000 with a bit more polish. PAE on 2000 is limted to the server editions as memory serves, and those editions need a bit of help to play games correctly.
GPU: what are we looking at, 7900? x1900? what was the best that would play nice with 6x86 and drivers/win2x/xp/7
Depends more on the games you want to play. Oh, and the ServerWorks chipset has horrible AGP speeds. Off the top of my head, its limited to 2x speeds, or something. Which was perfectly adequate for the server/CAD workstations these motherboards were marketed towards.
MX300 or the Audigy 2. Again, depends on the Games you are target. As I recall the X-fi dropped support for some of the gaming audio features that were popular in the 2000 era. (A3D)
