First post, by fsinan
- Newbie
Hi Guys
I'm pretty old who experienced all these hardware in young ages, I'm 48. Started to build a DOS-Win3.11 PC. First tried to find a good 486 board, cause I have Cyrix DX2-50 and TI DX2-66 cpus but to no avail unfortunately. All went to scrapyards it seems.
Fortunately I found this Zida 5STX-J98 rev 1.01 board. Worked with Pentium-120 and also 150 with manual jumper settings and easy jumper function which detecs the cpu and you set the fsb and multiplier in bios, overclocked to 166 with success too. The board should support MMX series and AMD-K6 and K6-2 with latest bios. But no.
Tried MMX-200, manual jumpers but didnt boot at all, pci analyzer gives no-cpu message. Easy jumper boots at 166MMX, prompts to get in bios and set the cpu, action taken but at boot, shows Pentium-MMX cpu 200Mhz and hangs without any memory check. Cleared bios with "F" and "J" to redetect the cpu and it boots again to 166Mhz. Set to 166Mhz at bios but in case it gives checksum error. And recycles this way. No boot in to dos.
Tried K6-2-333 AFR-66 and pci analyzer gives no-cpu error. No success at all.
Online resources that I find clearly indicates that the board supports these cpus. What could be wrong? Checked the jumpers according to the manuals several times.
1. Could it be corrupted bios? Should I write it with 2.6 latest version again?
2. There are pictures of rev 1.02 board, mine is 1.01. Maybe this rev does not support these cpus and manuals are latest version? Is it possible? No detailed info on revs..
3. I'm doing wrong with the sequence of bios boot or this "F" or "J" press functions does not work as it should be and it does not clear cmos. Should I remove the battery to clear cmos?
And one more issue is the serial mouse. I couldnt make it work. I have a A4Tect 3D serial mouse with scroll wheel. I learned that the Zida mobo DB9 mapping is different, soldered to this config but still not working. Tested with short circuit anaylzer for the connection, it is ok. But mouse is not very old maybe it is not compatible with these old serial RS-232 connectors.
I asked many questions, sorry for the long message.
Any help will be greatly appreciated.
Very happy to see this forum.
System:1
Cyrix 5x86-100GP
Lucky Star LS-486E
System:2
AMD K6-2-475(Changing frequently with Cyrix 6x86MX PR-233)
Asus P5A-B
System:3
UMC U5S-40
486UL-P101
System:4
P3 Coppermine 800EB
Gigabyte GA-6BX7
