First post, by fsinan
Hi Guys
I'm pretty old who experienced all these hardware in young ages, I'm 48. Started to build a DOS-Win3.11 PC. First tried to find a good 486 board, cause I have Cyrix DX2-50 and TI DX2-66 cpus but to no avail unfortunately. All went to scrapyards it seems.
Fortunately I found this Zida 5STX-J98 rev 1.01 board. Worked with Pentium-120 and also 150 with manual jumper settings and easy jumper function which detecs the cpu and you set the fsb and multiplier in bios, overclocked to 166 with success too. The board should support MMX series and AMD-K6 and K6-2 with latest bios. But no.
Tried MMX-200, manual jumpers but didnt boot at all, pci analyzer gives no-cpu message. Easy jumper boots at 166MMX, prompts to get in bios and set the cpu, action taken but at boot, shows Pentium-MMX cpu 200Mhz and hangs without any memory check. Cleared bios with "F" and "J" to redetect the cpu and it boots again to 166Mhz. Set to 166Mhz at bios but in case it gives checksum error. And recycles this way. No boot in to dos.
Tried K6-2-333 AFR-66 and pci analyzer gives no-cpu error. No success at all.
Online resources that I find clearly indicates that the board supports these cpus. What could be wrong? Checked the jumpers according to the manuals several times.
1. Could it be corrupted bios? Should I write it with 2.6 latest version again?
2. There are pictures of rev 1.02 board, mine is 1.01. Maybe this rev does not support these cpus and manuals are latest version? Is it possible? No detailed info on revs..
3. I'm doing wrong with the sequence of bios boot or this "F" or "J" press functions does not work as it should be and it does not clear cmos. Should I remove the battery to clear cmos?
And one more issue is the serial mouse. I couldnt make it work. I have a A4Tect 3D serial mouse with scroll wheel. I learned that the Zida mobo DB9 mapping is different, soldered to this config but still not working. Tested with short circuit anaylzer for the connection, it is ok. But mouse is not very old maybe it is not compatible with these old serial RS-232 connectors.
I asked many questions, sorry for the long message.
Any help will be greatly appreciated.
Very happy to see this forum.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 1 of 24, by PC@LIVE
Hello and welcome,
so first you should put an image of the motherboard, then maybe also one of the CPU VRM area, the one with the mosfets (do they have cooling fins?), already from the images you can see if it supports dual-voltage CPUs, perhaps it could be a software problem, that is, if it doesn't recognize the K6s, it may be that they are not recognized by the BIOS, so perhaps the initial BIOS screen should also be photographed, just to understand what you have in that card.
Then of course there could be a HW problem, but first you need to be sure that everything is ok, so maybe even a photo of the jumpers, to select CPU and voltage.
Finally, the fastest dual voltage CPUs require switching regulators, I don't know if they are there in the MB one, I think you have linear regulators, in that case the more you go up in frequency, the more heat they develop, above 200 they start to be quite hot, but if you want to stay at 200 MHz, I recommend you add an additional fan.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 2 of 24, by fsinan
Mobo manual;
https://www.zida-bios.com/download-datasheets … -with-id-6.html
Tried Pentium MMX. Manual settings of jumpers:
as in picture 6248
The attachment IMG_6248.jpg is no longer available
Voltage set to 2.8
V0 1-2
V1 1-2
V2 1-2
V3 2-3
V4 1-2
BF jumpers as in picture 6249
The attachment IMG_6249.jpg is no longer available
Ratio 3x
BF0 1-2
BF1 2-3
BF2 1-2
JP jumpers as in picture 6250
The attachment IMG_6250.jpg is no longer available
FSB set to 66Mhz
Jp4 1-3, 2-4
JP5 1-2
JP14
set 1-2 easy bios mode
set 2-3 manual
First set to manual. NO boot at all.
With easy jumper mode, JP14 set to 1-2
System at first boots, as Pentium-166MMX. Everything normal as it should be. Boots into dos, doscheck with sysinfo etc. No problem.
Second boot entered into bios, as seen in picture 6262, set to 3x, 200Mhz.
The attachment IMG_6262.jpg is no longer available
Boots to picture 6263, no keyboard response, frozen. No memory check etc. PCI analyzer gives two codes as
The attachment IMG_6263.jpg is no longer available
Continues....
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 3 of 24, by fsinan
Mobo VRM
The attachment IMG_6251.jpg is no longer available
PCI bios analyzer gives two codes one for award one for itself, I couldnt resolve correctly;
The attachment IMG_6269.jpg is no longer available
The attachment IMG_6270.jpg is no longer available
I think about possibilities;
1.Mobo ver 1.01 does not support over 166Mhz
2.Jumper settings are different for this version.
3.Jumpers are faulty does not connect.
Any ideas?
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 4 of 24, by dominusprog
Jumper settings are probably incorrect.
https://theretroweb.com/motherboard/manual/35539.pdf
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 5 of 24, by fsinan
dominusprog wrote on 2024-01-10, 11:10:
Looked at this reference too. Jumpers are definitely in correct position.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 6 of 24, by dominusprog
Have you updated the BIOS?
Reply 7 of 24, by PC@LIVE
fsinan wrote on 2024-01-10, 11:03:
Mobo VRM IMG_6251.jpg […]
Any ideas?
Ok looking at the jumper settings, everything seems fine to me.
Now we need to understand what blocks booting at 200 MHz, since it can be done from BIOS, I would try to select 180 MHz (60 FSB 3X), it seems strange but it is important if it starts, then we'll see if nothing changes.
A check that I would do, but you should do it, is a check of the voltage on the mosfets, you don't have to check all the pins, but only the upper part of the mosfet (opposite to the one with three pins), put the black tip of the tester in the molex dell ' power supply (black wire), and with the red lead test the VRM mosfets, obviously select VCC in the tester, I think up to 20V (depends on the tester).
One of the mosfets will certainly be 3.3V (or 3.5?), another should be 2.8V, if you don't find this value, that would probably be the problem.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 8 of 24, by Chkcpu
dominusprog wrote on 2024-01-10, 16:26:
Good call! 😀
Hi fsinan,
An interesting and strange problem you have there!
To rule-out the BIOS as the cause, I have been looking into the VER2.6 (7/7/98) BIOS and found proper K6-2 support. However when testing this BIOS in a virtual i430TX machine in 86Box, I found that it would hang early during POST when using a CPU with MMX support.
So Pentium and WinChip C6 worked, but PentiumMMX and K6/K6-2 wouldn’t.
Very strange and I never saw this bug before on a socket 7 board.
Then I tested the VER2.3 (22/4/98) BIOS and that worked much better. All CPUs with MMX (except K6-2+/III+) worked fine now, including K6 and K6-2. Only with the K6-2 the BIOS indicated a K6(tm) 3D but this is just cosmetic.
Even the correct 2.20V Vcore was indicated in the BIOS, however the FSB/multiplier setting is limited to 66x4.5 (300MHz) in this BIOS version.
So my advise would be to try the VER2.3 BIOS and set Vcore/FSB/BF jumpers manually for your K6-2/366 AFR-66.
Regards, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 9 of 24, by fsinan
It is latest 2.6 bios.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 10 of 24, by analog_programmer
I don't know if this will help in your case as I own slightly older revision Zida Tomato 5STX 512KB (non-98) mobo and it refuses to boot at all if there's no healthy (2.8+ V) CMOS battery inserted. I own this board since 1998 and never had a single problem with it. Now it runs K6-2+ 500 (6 * 83 MHz) with modified BIOS.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 11 of 24, by fsinan
Chkcpu wrote on 2024-01-10, 17:51:
Good call! :) […]
Good call! 😀
Hi fsinan,
Regards, Jan
Wow, thats' something. I'll try immediately.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 12 of 24, by fsinan
fsinan wrote on 2024-01-10, 19:00:
Good call! :) […]
Good call! 😀
Hi fsinan,
Regards, Jan
Will check the CR2030 battery. Thanx!
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 13 of 24, by PC@LIVE
fsinan wrote on 2024-01-10, 18:35:
According to what Jan writes, if you have BIOS 2.6, P.MMX and K6 will not work, so you should install version 2.3, which has verified and should solve the boot failure problem.
He also suggests using the K6-2 on manual settings, and if that works, I think you'll have it sorted.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 14 of 24, by fsinan
PC@LIVE wrote on 2024-01-10, 16:59:
Ok looking at the jumper settings, everything seems fine to me. Now we need to understand what blocks booting at 200 MHz, since […]
Any ideas?
Here comes the strangest thing.
I immediately tested with my thrusty 😀 Mastech..
Two boots performed. Detected as Pentium MMX 200. Bios easy jumper nor manual. Manual does not work at all as I've wrote. First boot resulted with memory testing and hanged.
Here are the readings in order from mosfets near to bios chip, 5.10V
The attachment IMG_6276.jpg is no longer available
the one near to board edge, 2.23V I dont know if it is relevant or not...
The attachment IMG_6277.jpg is no longer available
the one near to cpu. 2.68V, it is probably CPU feed
The attachment IMG_6278.jpg is no longer available
Lover than it should be as 2.8.
Second boot could not perform Memory test.
These are the results in same order;
again 5.12
this time 1.46
this time 2.23 Much lower than 2.8.
Voltage dropped as I understand at the output of the VRM at second boot and it couldn't perform even memory count.
So changing voltage results. Maybe a faulty mosfet here. Probably. Or struggling bios code.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 15 of 24, by fsinan
PC@LIVE wrote on 2024-01-10, 19:13:
Will try it. With a "proper" Pentium 😀
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 16 of 24, by Hoping
I also have a Zida 5STX that came to me with a burned out mosfet. The manual specifically states that you have to change a jumper if you use a normal Pentium or a Pentium MMX and that if you don't change the motherboard it will burn out. I have never felt like trying to find what mosfets it uses since the one that is burned out cannot be read anything and I don't know which one it is.
So these motherboards may be a little special with the Pentium MMX.
Reply 17 of 24, by PC@LIVE
fsinan wrote on 2024-01-10, 19:21:
Here comes the strangest thing. […]
Any ideas?
Here are the readings in order from mosfets near to bios chip, 5.10V IMG_6276.jpg
the one near to board edge, 2.23V I dont know if it is relevant or not...IMG_6277.jpg
again 5.12
this time 1.46
In my opinion there could be a problem, that there are 5V is normal I think, they probably come directly from the power supply, one of the voltages should be 3.3V, which would be that of the I/O, at most it could be around 3.5V, but not 2.2V or 2.7V, the second measurement is even stranger, but I think it is due to an adjustment of the BIOS, that is, it initially starts with values ​​that are not dangerous for the life of the CPU, and then having selected the type of CPU and the speed, adjusts the values ​​using the correct ones, I imagine they are stored in the BIOS, for example a 366 K6-2, has two voltages, 3.3V I/O and 2.2V VCORE, so in the mosfets you should have those voltages (more or less 0.1V).
But since Jan verified problems with BIOS 2.6, I would try version 2.3 first, maybe there is an incorrect voltage in version 2.6, and this would explain why it doesn't work, but if you use manual settings, you could see the voltages on the mosfets , if they do not change, there could be a problem with one or more mosfets, if they go to normal values, the mosfets are fine.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 18 of 24, by fsinan
Tried bios 2.3.
First boot, detected as pentium 125MMX, bios message appeared to set new cpu settings. Entered, set to 200MMX. Rebooted, frozen after memory count.
Tried 166. No success. Wll try K6-2 with manual settings tomorrow.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 19 of 24, by fsinan
Some news here.
I've looked at the output of VRM for every manual setting.
Board gives approximately 0.7 volf below the setted voltage so set to 3.2 for Pentium MMX and booted and worked flawlessly at 2.6V. Bios version is 2.3.
Set 2.9 for K6-2 as it should be 2.9 but output is 1.2V. It doesnt change with jumper settings. I dont know that bios effects the voltage in this case but will look for 2.6 bios now.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
