Reply 52800 of 53144, by Shadzilla
PC Hoarder Patrol wrote on 2024-04-29, 10:33:
Shadzilla wrote on 2024-04-29, 07:42:
LoK wrote on 2024-04-29, 00:24:
This is definitely some kind of Inwin S5xx branded as Systemax. https://en.wikipedia.org/wiki/Global_Industrial_Company […]
Oh nice find! Yes it looks like you're absolutely right, mine just has a different front panel. It looks like I might be missing some 5-1/4" bay sleds too, that's annoying.
The info pic on the back suggests it might be an Enlight case (compare yours on the right with my two current Enlight cases, centre & left)
It could be, unless those stickers were generic and mass produced for case manufacturers perhaps. Apart from the front panel my case looks to be an exact match for the previously posted schematic.
Reply 52801 of 53144, by myne
Dan386DX wrote on 2024-04-26, 18:57:
I'm sorta, kinda, maybe considering buying this old mystery PC as a project. […]
Anyone care to venture what the motherboard looks like from this very limited eBay listing?
Seller has no info about the PC.
I can see it's ATX, 4 dimms EDIT: Actually, looks like 2x2 different RAM kinds. (1 AGP?) 1 AMR. 5 PCI and and I think I see an ISA lurking in the shadows at the bottom.
https://theretroweb.com/motherboards/s/pcchips-m930dafulr
Mostly lines up. Probably a different revision. The notable difference is between the PCI slot and southbridge. Something's different there, but everything else looks spot on,
And now I look, even with the terrible lighting, the ram slot has a hint of blue, and the board a hint of red.
I'd expect whatever the cheapest 478 Celeron was in ~2002-3
The biggest hint that it was a hunk of junk, that led me to find that board was the Xcel southbridge (SIS with a cheap respray)
Things I built:
Mechwarrior 2 installer for Windows 10/11 Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 52802 of 53144, by squeeb
Recent pickups - G200 and G400 Max.
Unfortunately the G200 has artifacts 😭
434.73 KiB
398 KiB
- FX-6300/ R9 290x/Sound Blaster X-Fi (Win7)
- Pentium III/G400 Max/Vortex 2 (Win98)
- Pentium III/Voodoo 3 2000/XWave 6000 (Win95)
- MT32-pi, Roland SC-88, Yamaha MU500
Reply 52803 of 53144, by H3nrik V!
squeeb wrote on 2024-04-29, 15:30:
Recent pickups - G200 and G400 Max. […]
But if the G400Max works, so be our work it with the G200; IIRC they're a lot more common?
[edit] Major typo 🤣 Hopefully makes sense now ...
Reply 52804 of 53144, by myne
Got a soldering iron?
I'd first try reflow the passives around the memory see if that works.
Then replace caps.
Then replace the ram. There is testing software that might be able to isolate the exact chip.
Then try reflow the core.
Things I built:
Reply 52805 of 53144, by squeeb
H3nrik V! wrote on 2024-04-29, 15:54:
Indeed, the G200 is more common so I'm not too distraught over it!
myne wrote on 2024-04-30, 04:41:
Got a soldering iron? I'd first try reflow the passives around the memory see if that works. Then replace caps. Then replace th […]
Then replace caps.
Thanks for the advice. My thoughts immediately went to the vram. I do have a soldering iron, perhaps I'll give some of the components [you mentioned] a reflow.
Reply 52806 of 53144, by Jccwu
A friend sent me a new cooler for my P3-1400
Reply 52807 of 53144, by oh2ftu
oh2ftu wrote on 2024-04-29, 08:30:
Two voodoo2 and one voodoo3 agp. Untested, unknown condition. A good deal if they work. If not... well it was an auction. Don't judge me 😀
Oh my!
At least the V3-2000 and both V2 works. Well, these are just preliminary tests (Q2 timedemo works).
I had to install a new testbench, my P3-1Ghz seemed a little too much. Although it might've taken a slower celeron as well.
Now running on a GA-6PMM (via PM133 or similar) with Cel466 😀 (I don't have a 440BX mobo (yet))
Reply 52811 of 53144, by zecahue
dexvx wrote on 2017-11-08, 21:06:
Looks like OPL YMF715-S and GM YMF721-S.
I'v bought the same today, waiting to arrive.
Do you still have it? Care to share some information?
I am curious to understand why this board uses both an opl3 and opl4 chip, because in theory the 721 also has an opl3.
Reply 52812 of 53144, by Tiido
YMF721 is for MIDI music, and when the DAC inside YMF71x is used for the MIDI chip, OPL3 internal to YMF71x has no more output and one in YMF721 takes its place instead. It is possible to have both OPL3 as on my YMF71x card but it requires external DAC chip for YMF704/721.
Reply 52813 of 53144, by rasz_pl
Pino wrote on 2024-05-01, 20:37:
demiurge wrote on 2024-04-30, 22:01:
Post the new S3 S27 to https://vgamuseum.info/
That is a unicorn!
Really though to find one.
indeed What is the deal with S3's Chrome cards?
Reply 52814 of 53144, by Ozzuneoj
I have found all sorts of cool PC hardware lately (will post more at some point), but this one caught me off guard. I bought a Sound Blaster 2.0 box with most of the disks and other stuff in it, and the seller included this as a surprise freebie:
639.9 KiB
Anyone ever seen one of these? Looks like a mirror that you'd stick on the wall of your cubicle so you could know when the boss was coming. It has a sticky pad on the back that hasn't been used and it came in a little plastic bag. I'm assuming these were a common trade show table item and Creative had some made with their logo to hand out to visitors.
Judging from the other items that the seller had, and the fact that they also sent me a handful of random 5.25" floppies, I'm guessing this isn't a recent promo item. In fact, it's such a goofy\cheap looking promo item that I would guess that it came from the Creative of the early to mid 90s, rather than the behemoth of the late 90s to early 2000s... but I can't say for sure.
Reply 52815 of 53144, by 3lectr1c
Ensign Nemo wrote on 2024-04-28, 23:46:
GPU: Nvidia GeForce 8600M GT
Should indeed be a decent XP gaming system as long as it works, but I'll warn you that the GPU it has is extremely unreliable (bumpgate)
I probably have too many old laptops.
Reply 52816 of 53144, by Ensign Nemo
3lectr1c wrote on 2024-05-04, 02:25:
Thanks for the heads-up. Hopefully, I'll get a bit of life out of it. Apart from the GPU, the entire laptop does get a bit toasty.
Reply 52817 of 53144, by BitWrangler
Ozzuneoj wrote on 2024-05-03, 23:33:
I have found all sorts of cool PC hardware lately (will post more at some point), but this one caught me off guard. I bought a S […]
I'm slow tonight, spent seconds too long wondering what a punos card was (pic)
Those mirrors were usually intended to go on the bezel of a monitor I think, so you could see anyone coming up behind you or shoulder surfing your stuff. "Monitor rearview" kind of thing. Monitors usually had much wider bezels in the CRT days of course.
Reply 52818 of 53144, by PcBytes
Ensign Nemo wrote on 2024-05-04, 03:22:
Check when was the laptop built. 8600M GTs made after sometime in 2008 have the fixed underfill that was subsequently used in Geforce 9 series.
Or, if you open it up, look at the GPU die and numbering.
The rules I know of:
- even models are defective (e.g G84-770-A2)
- odd models are fixed (e.g G84-771-A2)
- revised G84 and G86 chips should have a milky coloured underfill (have had a revised G86 from an Acer, renamed into 9300MG, actual card being a 8400MG)
Reply 52819 of 53144, by Ensign Nemo
PcBytes wrote on 2024-05-04, 08:48:
Check when was the laptop built. 8600M GTs made after sometime in 2008 have the fixed underfill that was subsequently used in Ge […]
Thanks for the info! I'll see if it's not too difficult to open up.
