Reply 2640 of 29624, by dexter311
That's a compact little mobo, Phil! I've been getting increasingly drawn to building a compact DOS build using an mATX Socket 7 board (hopefully with 2 ISA slots), a Pentium, S3 Trio, Voodoo1, AWE32 or SB16... would be a cool little build. Bonus points for putting it in a white Silverstone SG02 - the perfect tiny DOS build IMO! A bit pointless putting such a build into a 90eur case though...
In other news, I'm working on configuring Duriel, my Pentium 4 build. I chucked in my second WD Raptor 36GB and set up a RAID0 using the P4P800-E's onboard Promise FastTrack 378 controller. The array built perfectly, and Windows XP setup is installing to the freshly formatted array nicely! It's my first foray into RAID boot disks, and I'm hoping for screaming speed from these 10k RPM monsters!
